hi ive been looking on line for rio palisander rosewood for my beomaster 6000 but have had no luck but I have found indian palisander rosewood would this be the same type of veneer or is it darker than the rio and would it be ok to use on the beomaster ? thanks for any help
hi dave thanks for your advice I do need inuff for the beomaster 6000 and the beocord 6000 as need them to match if so let me know ? if you can help thanks
lotus73jps: hi dave thanks for your advice I do need inuff for the beomaster 6000 and the beocord 6000 as need them to match if so let me know ? if you can help thanks
Can you send me the dimensions that you need as I have to build in some excess. i.e. length and width of pieces needed. I have a ton of veneers but I'm not sure if I have any Rosewood. I haven't looked for ages. The pieces my be too small also which is why I suggested the seller earlier.
Are you used to handling veneers?
Dave.
hi dave handling veneer 50/50 but my son is a joiner so should be ok but if you have any tips on how to go will help the beomaster 6000 front is L53mx3m the sides are 29m x6 as they slop that would be the same for the beocord dave if you can help let me know will send money over to you regards shaun
Hi Shaun,
I checked in the workshop today and I have no Rosewood of any type! A bit remiss of me as I will also need one at some stage. Sorry. I do have some fantastic veneers with gorgeous figure and colour but it would make a unique B&O piece!
I'd try the bay seller I mentioned earlier - he has the Rosewood you want and good feedback too. You can still find it. It just takes some hard searching.
If I can help in any way, just ask.
hi dave thanks for your help I will try the indian rosewood I found on ebay have a good look at it first before I begin regards shaun
