Eclipse 65V1-32Beosound M5Essence MK2BLI
could you post some screen shots of the configuration of the converter?
Reconsider your IR mapping configuration, why are you directing all those inputs to the converter? There is no input possible on Vmem, Camera, etc... on the converter, place all inputs you don't need including Vmem to 'Empty'.
"Believe nothing you read and only half of what you see, let your ears tell you the truth."
Configure the buttons you want to use on your ML, everything you don't want to use direct it to 'Empty'. In my case I'm using Vmem to listen to Deezer coming from my V1.
And now Vmem has no function anymore on the ML, the remote button won't work anymore on the ML. If you do the same on IR mapping it won't work anymore on your V1 (now you are directing (pointing) it to the converter !).
Seanie_230:Once I did this and saved the ones that should be there reappeared
BeoNut since '75
