Moment behaviour
This post has 7 Replies | 2 Followers
Seanie_230
UK
Posts 2,278
Seanie_230 Posted: Sat, Nov 14 2015 3:28 PM
Hello all
I have a moment in a room with speakers directly connected and accessed via Convertor for my ML devices.
I have noticed if I call up VMEM for example is works fine on ML devices but also switches on the moment speakers which is annoying.
If I select a source from the V1 on NL network the same happens, the v1 comes on with the correct source (excellent) is also put the music on in the room with the speakers connected to the moment.
Is this normal or have I setup something wrong?
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sat, Nov 14 2015 4:03 PM
could you post some screen shots of the configuration of the converter?
Seanie_230
UK
Posts 2,278
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Chris
Ostend-BE
Posts 1,170
Reconsider your IR mapping configuration, why are you directing all those inputs to the converter? There is no input possible on Vmem, Camera, etc... on the converter, place all inputs you don't need including Vmem to 'Empty'.
"Believe nothing you read and only half of what you see, let your ears tell you the truth."
Chris
Ostend-BE
Posts 1,170
Configure the buttons you want to use on your ML, everything you don't want to use direct it to 'Empty'. In my case I'm using Vmem to listen to Deezer coming from my V1.
Chris
Ostend-BE
Posts 1,170
And now Vmem has no function anymore on the ML, the remote button won't work anymore on the ML. If you do the same on IR mapping it won't work anymore on your V1 (now you are directing (pointing) it to the converter !).
Seanie_230
UK
Posts 2,278
Seanie_230 replied on Mon, Nov 23 2015 11:20 PM
Hi there
I changed all settings back to empty for IR and cleared the other things you recommended.
Once I did this and saved the ones that should be there reappeared
The moments local speakers still switch on when I activate from another room.
Sean
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
elephant
AU
Posts 8,219
elephant replied on Tue, Nov 24 2015 10:46 PM
Seanie_230:
Not sure I quite understand what you are saying.
However after saving the BLC's settings I found that I had to force a reboot for the new settings to take effect.
Rather than fiddle with toothpicks in pinholes mostly I simply do a power off/wait 19 seconds/power on cycle
BeoNut since '75
Page 1 of 1 (8 items) | RSS
