DOES B&O AV 9000 HAVE SPEAKERS IN THE MONITOR?
This post has 9 Replies | 1 Follower
francisford
Posts 6
francisford Posted: Thu, Nov 19 2015 12:24 PM
A friend of mine has a AV9000 system. She bought a new tv and she offered me, her old B&O tv (from 1993). Does it have internal speakers? Will it work without the loudspeaker?
Thanks!!! Smile
badgersurf
Posts 539
badgersurf replied on Thu, Nov 19 2015 12:42 PM
The beosystem AV9000 has a mono speaker under the TV, you can then connect front and rear beolbs for a 5.0 system
http://www.beoworld.org/prod_details.asp?pid=865
francisford
Posts 6
First of all, thanks!!!
So, the mono speaker on the front works as a satelite speaker for the others, but it also works as a stand alone, right?
francisford
Posts 6
francisford
Posts 6
phil
Posts 40
phil replied on Thu, Nov 19 2015 5:14 PM
The centre speaker on the AV 9000 will work  just on its own if you have no surround powerlink speakers connected to it, you will just get mono sound from it.
stefan
200 miles from Struer
Posts 2,920
stefan replied on Fri, Nov 20 2015 4:26 PM
badgersurf:
Not quite right. AV9000 uses a 4 channel decoder, the old Dolby Pro Logic. It`s a matrix based decoder, that creates 4 channels from a single stereo track. In SPEAKER 1 mode it will play front channels in mono.
Stefan
Millemissen
Flensborg, Denmark
Posts 14,680
A friend of mine had the AV9000 (the last one from the assembly line, he told me) as standalone tv for some years.
I used to nick him for having the most expensive mono-tv of the world ;-)
francisford
Posts 6
Ahahahahah! You are so right! It´s was a quite expensive mono tv :) Again, perfect for old retro gaming Smile
francisford
Posts 6
is the B&O LX 6600 worth a try?
Page 1 of 1 (10 items) | RSS
