Hi folks, i want to change or switch the STB Chip between to Beosystem 2s.
The BS2 MkI has the newer one
The BS2 MKIII has the older one.
Is it possibile to change them?
How can I do this?
Is there a "how to do" here in the forum?
thanks a lot :-)
Beovision 12-65 NG, Beosystem 4, Beolab 7.2, Beolab 6000, Beolab 5, Beolab 4000, Playmaker, Beogram 5005, Beo4, Beo5, Beovision 7-32 MK3 (2x), Beovision 4.42, Beosystem 2 HD, Beolab 7.1, Beolab 7.4, Beovision 10-32, Beovision 6-26, Beosound Moment, Beosound 2300, Beosound Ouverture, Beogram TX2, Beogram 2404, Beomaster 3002, Beovox CX 75, Beovox CX 100, ibundo, Keyring.......
lano:Hi, The chips needs to be "peeled" out, either with a special tool or very carefully with a thin screw driver or similar.
I would definately recommend purchasing a PLCC extraction tool - search on ebay, they cost next to nothing and dramatically reduce the risk of breaking the socket.
Kind Regards,
Martin.
At the top of the page, click on Main Site, then on Products, then follow the link on that page for User and Service Manuals.
found the manuals but I DIDN´T find the STB chip :-(
