h
I have a WD Live HUb connected to a BV-4.
I would like to control the WD via Beo4 but i do not have any ideea how to do that. It seems that there is a PUC available that control the WD but i do not have any clue on how to do it.
Any help will by highly appreciate!
Thanks in advance!
Good morning,
I will answer as nobody has ever replied yet.
Do you have just the screen or you also have a Beosystem 3 or 4 as well? The PUC control is done by the Beosystem A/V processor, not the Beovision 4 screen itself, which is just a monitor.
Regards,
Jean
hi Jean,
thanks for the reply!
I have the Beosystem 1connected to the BV4-50.
If i remember correctly the SW is 4.9.
Thanks again!
I doubt that the STB chip for the BS1 has WDLive.
The PUC for the BS3 can be programmed for use with the WDLive (I have one here)
Beobuddy: I doubt that the STB chip for the BS1 has WDLive. The PUC for the BS3 can be programmed for use with the WDLive (I have one here)
hi,
I am about to buy a Beovision 4-65 MK3 that comes with a Beosystem 3. I would appreciate if you give me more details about the PUC. I have WD in almost every room of my house.
thanks in advance
11048437: hi, I am about to buy a Beovision 4-65 MK3 that comes with a Beosystem 3. I would appreciate if you give me more details about the PUC. I have WD in almost every room of my house. thanks in advance
Good evening,
The PUC table on the Beosystem 3 has to be updated with the service tool which is available only to B&O technicians if the WD Live entry is not on the list. Check first if it is already loaded on your future Beosystem 3.
Good luck,
Done mine.
