Hi all,
I am quite new to the B&O trend but recently I've had a system installed in a new renovation that we've completed. Although the initial installation was done by a B&O engineer I am not venturing to improve the programming and the features available.
The system is simple and consists of an avant 55, moment, blgw and 3 rooms with an essence mk2 in each. What I am trying to determine is when programming triggers on the blgw is it possible to trigger commands using source selection/profile 1/2 selection on the beoremote 1. Currently I am using the Status_Update command and it is not very efficient.
If anyone has any ideas as to how I can programme this is would be really helpful.
Thanks all,
Alex
Thanks for coming back.
Yes - I can explain with the attached screen shot. The command basically makes one virtual LED button light in a few different zones (Movie) and make the others turn off. The trigger is where I'm having the issue. Currently this is triggered when the Status_Update trigger states the sourceName=AppleTV!. However, I would like it to trigger on the IR command from the Beo Remote 1. The status update method doesn't seem to be too effective all the time.
Any ideas would be welcome.
Cheers,
Screen shot attached
What are you trying to achieve would be the better question?
Ah, you know... A little B&O here, a little there
I am trying to trigger commands from the beo remote 1.
Thanks for writing back but I'm not sure this is what i'm looking to do. We can take another example. When I select the Apple TV from my BR1 I want the system to recognise this and then perform a command off the back of that. The specific command relates to switching some buttons with LEDs on/off.
So pressing Personal 1 on my BR1 triggers Apple TV and a specific speaker group. We can use Personal 1 Under the Command section of a macro but not the Event section and it's here I want to use it.
Any further ideas?
Ah ok the reason I want to be able to do this is because I have a series of LED buttons highlighting if the TV is on or if Apple TV is on or if the music is playing. See attached. Can anyone think of a way to incorporate this? It's good as it allows me to see whats on/off when i'm away from the property
ahjrennie:Ah ok the reason I want to be able to do this is because I have a series of LED buttons highlighting if the TV is on or if Apple TV is on or if the music is playing. See attached. Can anyone think of a way to incorporate this? It's good as it allows me to see whats on/off when i'm away from the property Cheers, Alex
BeoVision Eclipse 55”, Beolab 18s, Beolab 19s, Beosound 1, Beoplay P2, H3, BeoRemote One IR, BeoRemote One BT, Beoplay S8, Beosound Essence MkII, BeoTime
