Hi Chris,
there's no way to get a direct Line-In or Bluetooth connection to the BeoLab2000.
Steve from Sounds Heavenly tried it one or two years ago.Maybe he knows more in the meantime.
Ralph-Marcus
Almando have this product:
https://almando.com/index.php/b-o/almando-masterplay.html
Isn't it possible to use it with a Beolink 1611 converter as a standalone audio system? Would be much cheaper than the almando version...
TWG: Isn't it possible to use it with a Beolink 1611 converter as a standalone audio system? Would be much cheaper than the almando version...
Yes, you can use an Beolink 1611 converter, just need the Masterlink cable, and an AUX cable into the converter. Then selct A.AUX (I have had some issues with this, but I got mine to work with TV or V.TAPE)
/Weebyx
Leslie Nelwan suggested using a Beolink 1611 too. He actually had an iPad set up with a BL2000 on a video on his facebook page but the video doesn't seem to work now. Leslie hasn't posted on Beoworld for some time but his facebook page gives the impression that his B&O hobby is quite a big enterprise!
Graham
Weebyx: ... Yes, you can use an Beolink 1611 converter, just need the Masterlink cable, and an AUX cable into the converter. Then selct A.AUX (I have had some issues with this, but I got mine to work with TV or V.TAPE) /Weebyx
But then Chris needs two B&O (compatible) remotes or he has luck and those two Beolab2000s are the new one with a TV button on the panel (which is a bit unlogical for his kids )
Oh no, Chris - don't do that to your kids.
Give them the A2's and tell them, that is for next christmas too
Chris Townsend:The reason I ask is because there are two mint ones for sale just down the road. Am trying to help the indoctrination of my three young boys along, all of whom are steadily listening to more music. Three A2's are a step too far this Xmas, considering all the other Chinese junk they are about to receive!
You're buying them oriental sailing vessels Chris!
Some would be content with a bicycle..
Beo Century ,Beoplay V1, Beocenter 6, Ex-Beolit 12, Beotime , A8. Beolit 15 , Form 2i , Beolab 2000, Beoplay A3.Beosound 1
use this:
https://store.google.com/category/tv_and_audio
madsholme: use this: https://store.google.com/category/tv_and_audio
Not sure if there's a Masterlink connection on the Google product?
No solution to what the OP what to achieve with a BL2000.
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
