Providing all four televisions are current (eg BV11 or BV Avant) and therefore support the Beoremote One command set (as opposed to needing 'beo4' mode control), then I believe you can add up to eight televisions and eight audio products to the BR One product list and control each product individually.
Also, I guess a maximum of two of those could be older beovisions if you wanted, as you could put one in v.opt 1 or 2 and the other in option 4 (the remaining Beovisions would have to support native BR One control as above).
Kind Regards,
Martin.
To make it simple, I recommend to just set each TV to a unique IR address
This is very simple to do with the BeoRemore One under settings, remember to be very close to the TV when sending the IR address programming command as the remote sends that out with a very short range strength
Now each TV will only respond to commands from the BeoRemote when the correct "Product Zone" is selected: BeoVision 1 = IR address 1 and BeoVision 2 = IR address 2 and so on ...... It's fairly easy to operate it this way and its also very quick to setup and rename each TV to something meaningful on the BeoRemote One
Happy Holidays
mjmedlo:I am aware of the beoremote one capabilities. My question is.. How will the television know which one it is?
You can set the IR 'option' for each Beovision with the remote (different from the old ML options), so that each television then becomes 'BeoVision', 'BeoVision(2)', 'BeoVision(3)' and so on in turn (you can rename these on the BR One afterwards).
mjmedlo:Have you tried this?
I haven't as I don't yet have either a BR One or a NL BeoVision (let alone more than one), but I've seen it used in B&O stores as it is how they tend to control the multiple televisions on display there.
Oops, realised after I'd posted that BeoLinkapp had already provided a response with this info...
