BeoSound 35 & Moment
Azuntila
Finland
Posts 8
Azuntila Posted: Thu, Jan 7 2016 1:54 PM
Hi all,
been reading BeoWorld forum for a quite long time, but not until now decided to join in BIG time and made my "membership application" :)
Just thinking how would new superb BS35 work with BS Moment and pair of BS6002? Can BS35 used as BS3500 was designed to work as a satellite speaker?
Thanks and nice to be Inner Circle :D
Michael
Denmark
Posts 67
Michael replied on Thu, Jan 7 2016 2:17 PM
Welcome to the inner circle.
Check out this video, nice info about the use as a soundbar.
https://youtu.be/1SUizSJfCwI
Cheers
Hiort
Sweden
Posts 2,895
Hiort replied on Thu, Jan 7 2016 3:39 PM
Welcome :)
Azuntila:
BS35 can work as a satellite speaker in your setup. If you start a source in BS35, you can join that source from the Moment and vice versa. Or play different sources on Moment and BS35 individually. All without Masterlink cables.
Millemissen
Flensborg, Denmark
Posts 14,680
I would not call it a 'satelite' speaker.
Both devices are equal 'sources on your NL network' - the BS Moment having the specific features: MoodWheel and PatternPlay.
Depending on how you use these two, either one could be the 'satelite'.
This is the difference between a ML network and a NL network.
Hiort
Sweden
Posts 2,895
Hiort replied on Fri, Jan 8 2016 8:12 AM
Millemissen:
I did not call it a satellite speaker. I said it could act as a satellite speaker, to answer the OP question Wink
Millemissen
Flensborg, Denmark
Posts 14,680
@Hiort
I am quite sure, you are fully aware of how this works.
All I wanted, was to point out the difference between a ML (base and satelite) setup and the NL (co-working equal units) setup.
Of course it can work as a satelite - if that is, what someone wants.
Page 1 of 1 (6 items) | RSS
