Hi all,
been reading BeoWorld forum for a quite long time, but not until now decided to join in BIG time and made my "membership application" :)
Just thinking how would new superb BS35 work with BS Moment and pair of BS6002? Can BS35 used as BS3500 was designed to work as a satellite speaker?
Thanks and nice to be Inner Circle :D
Welcome to the inner circle.
Check out this video, nice info about the use as a soundbar.
https://youtu.be/1SUizSJfCwI
Cheers
Welcome :)
Azuntila: Just thinking how would new superb BS35 work with BS Moment and pair of BS6002? Can BS35 used as BS3500 was designed to work as a satellite speaker?
BS35 can work as a satellite speaker in your setup. If you start a source in BS35, you can join that source from the Moment and vice versa. Or play different sources on Moment and BS35 individually. All without Masterlink cables.
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
I would not call it a 'satelite' speaker.
Both devices are equal 'sources on your NL network' - the BS Moment having the specific features: MoodWheel and PatternPlay.
Depending on how you use these two, either one could be the 'satelite'.
This is the difference between a ML network and a NL network.
Millemissen: I would not call it a 'satelite' speaker.
I did not call it a satellite speaker. I said it could act as a satellite speaker, to answer the OP question
@Hiort
I am quite sure, you are fully aware of how this works.
All I wanted, was to point out the difference between a ML (base and satelite) setup and the NL (co-working equal units) setup.
Of course it can work as a satelite - if that is, what someone wants.
