FOUR Essence Mkii controlled by Beomusic App on iPhone6 - BIG Problems
This post has 7 Replies | 2 Followers
stephenlion
Posts 2
stephenlion Posted: Fri, Jan 8 2016 1:38 PM
I have four Essence MKii and a Moment. On the BeoMusic App the Essences don't always all show up. Sometimes Linking them is not possible, other times it takes ages for them to do it. Restarting the App helps for a short moment - sometimes. Restarting the Essence hasn't helped.
It has also happened that the Plus signs for linking don't show up or that I could do everything except change the volume of a device.
Anyone, any ideas?`
regards
Stephen
Hiort
Sweden
Posts 2,895
Hiort replied on Fri, Jan 8 2016 2:39 PM
Not much help maybe, but have you tried restarting your (WIFI) router?
lonfred
Posts 200
lonfred replied on Fri, Jan 8 2016 2:55 PM
I had the same problem with my Moment in the beginning, fixed Ethernet connection for the Moment and proffessional wi-fi access points solved the problem.
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Fri, Jan 8 2016 3:47 PM
Hi Stephen
install the BeoTool on your iDevice and see for your self where the problem originate...
Chris
Ostend-BE
Posts 1,170
Chris replied on Fri, Jan 8 2016 3:48 PM
lonfred:
Excellent solution to many problems, to problems that not always appearing in using consumer goods but suddenly show up after buying NL products from B&O.
Low priced stable enterprise access is already price worthy from Ubiquity.
"Believe nothing you read and only half of what you see, let your ears tell you the truth."
stephenlion
Posts 2
Switch restart sometimes helps. All units are in the wired LAN. Only  iPhones are in the wifi..
lonfred
Posts 200
lonfred replied on Fri, Jan 8 2016 4:46 PM
Then the problem sounds to be the access point.
riverstyx
SouthWest UK
Posts 938
I would recommend setting an IP address reservation for each of your netlink products using your routers configuration page, or failing that, configuring each of the products to use a fixed IP address as this may alleviate the issues you are having with products randomly disappearing and reappearing.
Kind Regards,
Martin.
Page 1 of 1 (8 items) | RSS
