A new thread to help B&O prioritize what needs to be fixed/added to BeoMusic of them to succeed (the current version has some very serious issues).
To start the list off:
I agree with your list phult, especially #1 & #3!!!
Here are some of my ideas, many selfish for my use case anyway:
Its not user friendly, its not handy to use, too much action in actually finding something, menu is a complete mess, no possibility for random play.
I'm thinking to reinstall iTunes, Jriver or Audirvana to have again a decent remote to control my music.
There is not other solution for Beomusic, rewrite that app and let it write from someone with less brain twisting.
"Believe nothing you read and only half of what you see, let your ears tell you the truth."
Sold mine (mk1) few days ago, but fwiw : add timer functionalities
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
lonfred:- It is to complicaded to choose a new track in the same playlist when a track from that playlist is playing. The best would be to only touch the name of the track to get back again to the playlist. Now I need to go the whole way around to change track in the same playlist. Maybe there is a better way but I have not found it. - There should be a Figurated Moment ML source in the app that not activate the speakers connected to the Moment when listen to music throw ML sources and controlling the Moment from the Beomusic app.
New blackboard?
or some input from users as on this thread.
Beo Century ,Beoplay V1, Beocenter 6, Ex-Beolit 12, Beotime , A8. Beolit 15 , Form 2i , Beolab 2000, Beoplay A3.Beosound 1
