Hello Beoteam
i am considering buying a Beoplay A9 to replace the BB6-26 in my kitchen as video is not really used and I love the NL music on a loud devise in my kitchen
What is the differences between gen1 and gen2?
cheers all
Eclipse 65V1-32Beosound M5Essence MK2BLI
Generation 1 is not capable of joining an NL network so no multiroom, so is badically stand alone.
Generation 2 is multiroom and has Bluetooth
Hi there
then this post is so worth it because NL is the reason I want it for the MultiRoom functionality.
Hello team
Another question or two
does the A9 pass light and control commands to the Beolink Gateway
can the A9 be controlled via the Beolink gateway and finally
cam you control an A9 with a beo-one remote control or only pair an essence to it?
thanks all
A9 mark 2 has no ir sensor so no direct control from Beo4 or BeoRemote1. I believe it can work via NLGW
Opman
