Hi all.
Found new Software from 1/6-2012 and made a sw.update on my Beovision 7-40 MKII
all seem OK. Put USB pin into tv and start upgrade. TV found new upgrade on the USB pin, and
I started to upgrade. First TV wrote " saving old software" then started to upgrade, and when
the bar was on 100% TV got black screen, and nothing happends. After ½ an hour I turned of TV, unplug
230V plug and wait 1 minute, the DTV cannot be turn on :-( . When I go into setup, and make a
RESET in monitor, i did not help, DTV is DEAD - Please help, ig anyone know what to do.
Thanks a lot
Regards
Per
PH:Hi all. Found new Software from 1/6-2012 and made a sw.update on my Beovision 7-40 MKII all seem OK. Put USB pin into tv and start upgrade. TV found new upgrade on the USB pin, and I started to upgrade. First TV wrote " saving old software" then started to upgrade, and when the bar was on 100% TV got black screen, and nothing happends. After ½ an hour I turned of TV, unplug 230V plug and wait 1 minute, the DTV cannot be turn on :-( . When I go into setup, and make a RESET in monitor, i did not help, DTV is DEAD - Please help, ig anyone know what to do. Thanks a lot Regards Per
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
I waited ½ an hour :-(
I think next TV is Samsung, it alwayes works
PH: I waited ½ an hour :-( I think next TV is Samsung, it alwayes works Regards Per
Same thing will happen on a Samsung TV, or a PC/Mac or anything almost. Unfortunately. You should have kept it going until something happened. Even if it seems like the firmware on the usb-stick might have been faulty so it could not continue. Half an hour is not much time but more than it should take to write a firmware of that size. Call your dealer or B&O and ask what they say. Don't dismiss the TV as crap because of a faulty update, it is just how things work. Software upgrades should only be performed if you are very sure about what you are doing.
Hi again. Yes I know that the TV must not be switch off, but ½ an hour is long time, so I think something when wrong.
I am my self an Tecnical repair man, who has repaired I think about 500 pieces og Bang and Olufsen MX5000-6000-7000 and before that Beovison 3400 was my first B&O TV in 1975 :-)
I have been working with industrial and TV/Radio service since 1982.
PH:Hi again. Yes I know that the TV must not be switch off, but ½ an hour is long time, so I think something when wrong. I am my self an Tecnical repair man, who has repaired I think about 500 pieces og Bang and Olufsen MX5000-6000-7000 and before that Beovison 3400 was my first B&O TV in 1975 :-) I have been working with industrial and TV/Radio service since 1982. Thanks Regards Per
Sorry, if you have a BV7-40 MKII it is the DVB T/S you are talking about? Not the newer DVB HD module?
As far as I know the sw update is meant only for the HD module...So, if it`s the DVB T/S it should be no problem to get a second life module for little money.
Stefan
Hi Stefan,
Sorry, yes it is the HD SW
9100260_SW_DVB_HD_MODULE_08_01.990.fpkg
But DVB-T now is dead :-(
Have someone the orginal "Hov to do restore" instruction ??
I have been told 3 different mode, how to restore HD software.
Switch off TV 5 minutes.
Put USB Pin with new SW into USB Slot Wait 5 minutes
Switch 230V But do NOT turn on TV with remote.
Wait 5 minutes
Switcf Off 230V main again, and wait 5 minutes,
Remove USB
Turn ON 230V main, and DTV Should work, but it does not :-(
Help ! Thanks a lot
Hi all. Have an B&O dealer on visit. The module is Dead :-(
one again 6000,- danish krones, I wonder why we are doing it?
Maybe the best was to buy a Samsung with new technology.
Hope B&O will sponsor a new module, the old one just
passed guarantee.
PH:Hi all. Have an B&O dealer on visit. The module is Dead :-( one again 6000,- danish krones, I wonder why we are doing it? Maybe the best was to buy a Samsung with new technology. Hope B&O will sponsor a new module, the old one just passed guarantee.
New DVB-T2 module installed, and it works perpect, but when the B&O dealer tried to update to 19.90, precily same problem, and now is module no. 2 dead. It is NOT possibel to recover, and
now they want to have the TV back to control, but I think something is wrong with the new update.
The new module have the USB plug, so nothing else can be wrong. Hope some have an idea ??
Det er en meget kendt fejl for os der monter Bang & Olufsen produkter.
Havde du en tekniker ude og se på dit tv, før han sagde at det var gået i stykker? Hvilken software har de to ICer der sidder i tv'et?
Hvor er du evt fra?
Det er en fejl jeg har set mange gange når jeg er ude på service ved mine kunder.
Hvilken software sidder i tvet altså ICerne, de skal helst være 30.08, og hvis ikke så skal de skiftes. Jeg sætter personligt selv nogle mærkater på produktet som følger med, så kunden selv kan se hvilken software der er i. Har din tekniker husket at opdatere tv'ets M2 software?
Hvor er du fra evt?
Hej Lasse. Ja det første teknikeren gjorde, efter at mit oprindelige modul var død, var at opdatere M2 til 30.08a, og da det var OK, forsøgte vi flere gange mes USB pinden, at få den til at recover data, men det lykkedes ikke. Det nye modul døde på samme måde, men da var M2 opdateret. Jeg har prøvet at recover med USB'en både med den gamle SW, og den nye SW, den reagerer IKKE - ØV.
USB pinden blinker når man tænder ved stikkontakten, og indtil standby LED tænder, derefter ingen reaktion. Jeg har fået at vide af B&O at den rigtige fremgangemåde er:
Sæt TV i stand by (Rød LED ON)
Sæt USB pind i USB stikket
Tænd i TV mode og vent 5 minutter.
Sluk TV - IKKE MED FJ.BETJ., men afbryd 230V til TV
Fjern USB
Tænd DTV - men ØV det virker ikke.
Har prøvet mindst 10 gange.
Jeg er selv tekniker og bor ved Løgstør
Hilsener
Det er mega nitte.
Har du lavet en reset to factory?
Der må næsten være et eller andet galt med dit tv, hvis den lige frem ødelægger to moduler.
Hej Lasse,
Ja Reset er prøvet. Jamen det kan vel ikke være TV'et. Det er jo selve modulet hvor USB sættes i der dør, og det modul er jo sig selv.
Mvh
Hej Per.
Er det kun modulet PCB 21 mener jeg det hedder, eller er det alt I har skiftet? For jeg har haft oplevet fejl på hoved printet, hvor også kun havde skiftet DVB-HD modulet
Vi var hos B&O et større Servicecenter med vores TV i går. De er B&O specialister.
DE FANDT FEJL OMGÅENDE!
og det var simpelthen, at AP SW ikke var skiftet. De 2 IC der medfølger modulet,
da de så monterede de 2 nye AP SW IC’er, kunne DVD modulet omgående hente opdateringen
på USB pinden, og det virker bare 100%. Servicemanden, monterede DVI kabel, og det fungerer
perfekt, selv om scalermodul ikke er Version E, men bare A. Så nu har vi et fantastisk billede. J
Man kunne ønske, at B&O skriver sammen deres download, at AP SW skal være
af nyere dato. Nå, men alt endte lykkeligt, og man kan holde ferie J
