BEOVISION 7-40 CONFIGURATION HDMI IMPUT
This post has 5 Replies | 0 Followers
Orfeof
Venice Italy
Posts 38
Orfeof Posted: Sun, Jan 24 2016 4:20 PM
Hello, please I need help. I connected to my Beovision 7-40 MKIII on the HDMI input a USB reader, after setting up the HDMI input, I can only see the USB source, but I don't hear.
I specify that the TV is without speakers, it has connected to BeoSystem 7000 using a BeoLink converter, the speakers are obviously connected to BeoSystem.
I did a test by connecting the speakers directly to the TV and everything works properly.
Am I doing wrong something, or is it not possible to do this?
Thanks to all
Orfeo
stefan
200 miles from Struer
Posts 2,920
stefan replied on Mon, Jan 25 2016 12:29 PM
if you have NO speakers (even no center..?) connected to your BV7, I`m not surprised, that you get no sound
You will need your BS7000 everytime you are usung the BV.
So set the BV7 to V.OPT 0 and your BS to A.OPT 2. Should work now....
All IR control will be received by the BM7000 and transmitted via the BL converter to your BV.
Selecting a video source will activate the BV with the selected source and activate the BM in AUX mode. It will also activate Beolabs if connected to the BM7000. Volume level control will be executed from the BM.
Hope this helps
Stefan
Orfeof
Venice Italy
Posts 38
Orfeof replied on Tue, Jan 26 2016 8:31 PM
Hello Stefan, probably I have not explained well, the problem isn't configure the BV 7, everything works properly, but I can not hear audio when using the HDMI input.
I hear usually  the BV sound trough the BS, using the Masterlink connection, and I think that Masterlink does not handle digital sources (eg HDMI).
As I explained to test I connected speakers directly to BV (without using the Masterlink connecton) and HDMI input works properly  (HDMI input configured in the same way).
Can anybody confirm this?
Millemissen
Flensborg, Denmark
Posts 14,680
You can not distribute a HDMI source on the link.
You will need an analog sound connection for that
Which 'USB-reader' are you using?
Frederic
Belgium
Posts 121
Frederic replied on Tue, Jan 26 2016 9:33 PM
Yes, a bit of a detour: you can get sound of hdmi input thowards the links but the BV7 has to be on and on that source (using picture mute afterwards if you want a black screen)
Orfeof
Venice Italy
Posts 38
Orfeof replied on Wed, Jan 27 2016 12:39 AM
Nothing special, it is a CYCLONE 2+MICRO, I'm using it for testing, let me turn to a raspberry.
Page 1 of 1 (6 items) | RSS
