Hello!I have a Beogram 3500, that I'm really happy about and I love the multiroom concept - so i want to integrate my beogram into the multiroom experience.With the multiroom concept, will I be able to control my beogram from another room with remote or/and with the app on my iPhone?
Connect the BG3500 with datalink capable Beomaster or Beosound.
Connect this system with ML to a NL/MCL converter (maybe you alo have to use a T1611).
Integrate the NL/ML converter in a NL system.
Then one can start and give basic commands to the BG3500 with a iPhone
Much easier...
Connect your BeoGram to a 'Line-In' connection of one of your NL-products.
Now you can access it from everywhere on the NL-network - using the BeoMusic app.
Of course you will have to start it manually, but since you have to put on the vinyl manually too, that shouldn't be a great problem. If it is - use the Carolpa-method!
Note: depending on your BeoGram you might need a RIAA-amp.
Millemissen: Much easier... Connect your BeoGram to a 'Line-In' connection of one of your NL-products. Now you can access it from everywhere on the NL-network - using the BeoMusic app. Of course you will have to start it manually, but since you have to put on the vinyl manually too, that shouldn't be a great problem. If it is - use the Carolpa-method! Note: depending on your BeoGram you might need a RIAA-amp. MM
Carolpa: you're right but it isn't the answer to the original question.
Sure - you are right!
But most people don't think of this way of doing it.
Investing in the converter - if you just need it for this - isn't something that everyone would do.
Can I connect the beogram directly to the "beolink converter nl/ml" or do I really need a beosound or beomaster product in between? :)
henriksnielsen: Can I connect the beogram directly to the "beolink converter nl/ml" or do I really need a beosound or beomaster product in between? :)
Then the controll of the BG3500 is manual
Okay - can you suggest any beomaster or beosound product? - i really only need it for the beogram
for example
BM3500, BM4500, BM6500, BM7000, BC2300 all with the use of a T1611
BS Ouverture, BS3000
Why do I have to use the 1611 converter?The Beolink NL/ML converter do have masterlink?
