Multiroom & BeoGram
This post has 14 Replies | 0 Followers
henriksnielsen
Posts 10
henriksnielsen Posted: Tue, Feb 9 2016 10:19 AM
Hello!
I have a Beogram 3500, that I'm really happy about and I love the multiroom concept - so i want to integrate my beogram into the multiroom experience.
With the multiroom concept, will I be able to control my beogram from another room with remote or/and with the app on my iPhone?
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Tue, Feb 9 2016 12:29 PM
Connect the BG3500 with datalink capable Beomaster or Beosound.
Connect this system with ML to a NL/MCL converter (maybe you alo have to use a T1611).
Integrate the NL/ML converter in a NL system.
Then one can start and give basic commands to the BG3500 with a iPhone
Millemissen
Flensborg, Denmark
Posts 14,680
Much easier...
Connect your BeoGram to a 'Line-In' connection of one of your NL-products.
Now you can access it from everywhere on the NL-network - using the BeoMusic app.
Of course you will have to start it manually, but since you have to put on the vinyl manually too, that shouldn't be a great problem. If it is - use the Carolpa-method!
Note: depending on your BeoGram you might need a RIAA-amp.
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Tue, Feb 9 2016 1:10 PM
Millemissen:
Much easier...
you're right but it isn't the answer to the original question.
Millemissen
Flensborg, Denmark
Posts 14,680
Carolpa:
Sure - you are right!
But most people don't think of this way of doing it.
Investing in the converter - if you just need it for this - isn't something that everyone would do.
henriksnielsen
Posts 10
Can I connect the beogram directly to the "beolink converter nl/ml" or do I really need a beosound or beomaster product in between? :)
henriksnielsen
Posts 10
henriksnielsen
Posts 10
henriksnielsen
Posts 10
henriksnielsen
Posts 10
henriksnielsen
Posts 10
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Tue, Feb 9 2016 3:11 PM
henriksnielsen:
YES: As MM discribed
Then the controll of the BG3500 is manual
henriksnielsen
Posts 10
Okay - can you suggest any beomaster or beosound product? - i really only need it for the beogram
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Tue, Feb 9 2016 6:43 PM
for example
BM3500, BM4500, BM6500, BM7000, BC2300 all with the use of a T1611
BS Ouverture, BS3000
henriksnielsen
Posts 10
Why do I have to use the 1611 converter?
The Beolink NL/ML converter do have masterlink?
Page 1 of 1 (15 items) | RSS
