Essence IR dosn´t work
Peanutboy
Posts 1
Peanutboy Posted: Mon, Mar 7 2016 6:07 PM
I have a Essence MKII with IR receiver. It worked fine and just suddently it dosn´t work anymore! The IR receiver greenlight is blinking then i turn the volume wheel on the beo5. It work with the buttons vol up and down on the IR reciever. Any suggestions?
TWG
Posts 1,672
TWG replied on Mon, Mar 7 2016 6:28 PM
Did you try a simple power on / power off with the essence? Unplug it from the mains for a minute, plug it in again. Does it show the same behaviour? Did you change any option programming of the Essence?
abyss
Posts 47
abyss replied on Mon, Mar 7 2016 7:24 PM
First of all, i would restart the Essence. If this is not working, i would try to reset the essence.
Very important: Did you try this?
http://bogo.custhelp.com/app/answers/detail/a_id/13309/~/how-do-i-activate-sources-using-beoremote-one-or-beo4%3F
carlito
Posts 239
carlito replied on Tue, Mar 8 2016 10:37 AM
Please read this thread
http://archivedforum2.beoworld.org/forums/t/18599.aspx?PageIndex=2
as mentioned already, try this:
To use Beo4, you must set the audio system in A.OPT 1.
Set A.OPT 1 with Beo4…
Point the Beo4 remote control at the IR-receiver of the audio system.
  • While holding down the • button, press LIST.
  • Let go of both buttons.
  • Press LIST repeatedly until OPTION? is shown in the Beo4 display and press GO.
  • Press LIST repeatedly until A.OPT is shown in the Beo4 display and then press the number button 1.
Page 1 of 1 (4 items) | RSS
