BeoSound 8: removing the iPhone connector
jc
Posts 80
jc Posted: Fri, Mar 11 2016 2:28 PM
I've got a BeoSound 8, but my iPhone 6 doesn't fit in the old connector. With the BeoPlay A8, you can change the connector, but with the BeoSound 8 that's not an option.
So, I'd just like to use it as an Airplay speaker, by connecting it to an Airport Express. But... then there's the connector sitting there for no reason other then sitting there.
Since it's a separate piece of plastic, is it possible to remove the iPhone connector competely and covering the whole with a replacement piece of plastic without a connector?
(or should I just get a saw....?)
Mark-N
Maryland, USA
Posts 320
Mark-N replied on Fri, Mar 11 2016 4:38 PM
I converted my BeoSound 8 to Airplay, but I just left the dock connector in place.  If nobody has an immediate answer I will attempt to disassemble mine when I get home and see how it is connected.  My initial reaction was "why bother" but now I am interested to see how it is connected.  Hopefully the dock connector just has a cable that plugs into the board.  Does the A8 have a blank plate to put in if you are not using a dock?
Aussie Michael
Melbourne, AU
Posts 3,730
I would also be interested to know because it's clear on the dock connector (30 pin) that it looks like a separate piece.
You could also use it as a computer speaker too, plug the USB from your laptop to the USB in the connections hub on the back and if you're running itunes from there, it could save having airplay.
Duels
England
Posts 2,553
Duels replied on Fri, Mar 11 2016 7:46 PM
Mine just has an ipad2 sitting on it with the old 30 pin connection. It's fine just to drive the bs8. Plus I always thought the whole piece looked at its best with an iPad in place.
Aussie Michael
Melbourne, AU
Posts 3,730
That's also a good solution - you could buy a second hand ipad and just sync your music on there and use it
It always did look better with just the ipad vs pod / phone
Mark-N
Maryland, USA
Posts 320
Mark-N replied on Fri, Mar 11 2016 9:01 PM
There appears to be four screws behind the access panel in the rear.  They are pretty short screws and they are not holding the cover on by themselves.  It looks like the white cover needs to be pried off.  I'm going to have to find out the correct way to open this up!
jc
Posts 80
jc replied on Wed, Mar 16 2016 1:23 PM
Mark-N:
That's what I'd like to know as well! Because one way or the other, it should be possible to remove the connector from the BS8. It's a separate piece after all, and if something can be put together, it can be taken apart.
But it would be nice if the whole could be covered with a blank plate.
Anyone?
The Beonic Man
Bristol
Posts 812
Maybe STB brackets or Steve @ Sounds Heavenly (links below) could make something up for you? Personally I think using an older iPad (I suggest third generation) would be the best solution and look best aesthetically. I had the BS8 for a while but then sold it on in favour of the A3 as I liked the extra portability coupled with the excellent sound reproduction.
Cheers,
Simon.
B&O products are V1-32, BS2, H95, E8 and an Essence remote.
11-46 now replaced with Sony A90J 65”, Sony HT-A9, Sony UBP-X800M2 and Sony SRS-NS7.
Page 1 of 1 (8 items) | RSS
