BV10 with Beosystem 3 - Question for Center Speaker
Tomvdw
Posts 177
Tomvdw Posted: Sun, Mar 13 2016 6:13 PM
planning to use a Beosystem 3 for home cinema reason in the living room where a BV10 alreay resides:
is it possibel to use the BV-Speaker as Center Speaker or do I have to install an additional speaker e.g. below to the TV ?
King Regards
Thomas
kallasr
Germany
Posts 2,562
kallasr replied on Mon, Mar 14 2016 7:32 AM
Hello Thomas,
did you search the (archived) forum on this subject?
http://archivedarchivedforum2.beoworld.org/forums/t/35319.aspx
It might be easier to use some sort of HDMI matrix/switch.
Ralf
Tomvdw
Posts 177
Tomvdw replied on Mon, Mar 14 2016 7:51 AM
Hi Ralf,
thanks for your suggestion, but my question is different to the linked one. I would like to use a beosystem 3 which controls my Beolabs and the beamer. I would like to use my BV10 as the primary display (beamer is the sencondary).
My question is: (how) can I use the build-in speaker of my BV10 as center in TV mode ?
The center in cinema mode will be another one.
Regards
Thomas
kallasr
Germany
Posts 2,562
kallasr replied on Mon, Mar 14 2016 8:51 AM
I understand.
I was just thinking about "why use a BS3 AND a BV in one room", if you might be able to use the processor inside the BV instead of a BS3...?
So you want to use the HDMI out of the BS3 and the HDMI in of the BV10?
No idea how this could work (option settings?)....
Ralf
Millemissen
Flensborg, Denmark
Posts 14,680
The only 'solution' I could think of, would be to connect all external speakers to the BSys3 and the HDMI-out (of the BSys3) - using a HDMI splitter - to the BV10 (HDMI-in/call it ? V.Mem) and your projector.
One of the devices would have to be in Option4, then - in order to control them in the same room.
N.B. The speaker of the BV10 would not be a 'real' center speaker, since it would work in stereo!
Kind off odd constellation, I must admit ;-)
Page 1 of 1 (5 items) | RSS
