hello lovely people
So i have a question
I have a Silent Gliss curtain track which responds to IR or a Button press to open and close.
I also have a BLGW.
How can I interface the Silent Gliss track with my BLGW? i Want to be able to use my Beoremote One to say curtains close or open, the BV7 receives the commend and sends it to the BLGW and then the macro on the gatway triggars a commend to the Silent Gliss track.
Question is how to interface with the track.
Any Idea's
Thanks All
Eclipse 65V1-32Beosound M5Essence MK2BLI
The question is whether or not it can be controlled via ip.
hi! look at this:
This driver supports communication with a Global Cache iTach IP2IR system, allowing to control IR controlled devices.
it is controllable from the blgw. maybe this helps.
BS Ouverture, BS 9000, AV 9000, Avant 32 DVD, BV9, BV6-22, BS 5, BS 4500, BS 7000, BC 9500, Beo6, BL Penta, F1000, BLGW, etc....
Hello Beoteam
Thanks for your help.
I also had a great reply from a Excellent fellow at Bang and Olufsen called Morten the systems intergration consultant who reccomended the same thing but with one small difference which is to use the relay version
His reply was very detailed and also gave me instructions on how to set it up a snap shot is below
In order to control the curtain with a relay which I think might be the most simple to do you can use the Global Cache IP2CC.
Hello All
Does anyone know the correct pins on the RJ11 for connection to a relay?
I seem to recall there being a device from Lintronic that can interface with ML to send out an IR blast in a link room.
If anyone is interested my Global Cache IP2CC is for sale in the for sale area as I no longer have the curtain track or a need for the device.
Sean
