I am planning to use the multi-room feature playing from the BeoMusic app to several rooms. A few questions:
1) Does the Beomusic app support itunes playlists?
2) Can I play from the beomusic app directly to the soundhub?
3) If playing from the beomusic app to a Beolink converter (connected to a BV5), does the line-in sensing allow to play audio without the television being turned on)?
Thanks in advance!
steve1977:1) Does the Beomusic app support itunes playlists?
steve1977:2) Can I play from the beomusic app directly to the soundhub?
steve1977:3) If playing from the beomusic app to a Beolink converter (connected to a BV5), does the line-in sensing allow to play audio without the television being turned on)?
Thanks for your message.
re 1 - also works without twonky? I prefer not to have a dlna server in between. Can the Beomusic app directly access the itunes library with playlists?
re 3 - not sure I understand. When I play to the ML/NL converter (BV5 is turned off), will it output to my Beolabs that are connected to the BV?
steve1977:re 1 - also works without twonky? I prefer not to have a dlna server in between. Can the Beomusic app directly access the itunes library with playlists?
steve1977:re 3 - not sure I understand. When I play to the ML/NL converter (BV5 is turned off), will it output to my Beolabs that are connected to the BV?
