Multi-room set-up
This post has 3 Replies | 0 Followers
steve1977
Posts 911
steve1977 Posted: Sun, Mar 20 2016 1:35 AM
I am planning to use the multi-room feature playing from the BeoMusic app to several rooms. A few questions:
1) Does the Beomusic app support itunes playlists?
2) Can I play from the beomusic app directly to the soundhub?
3) If playing from the beomusic app to a Beolink converter (connected to a BV5), does the line-in sensing allow to play audio without the television being turned on)?
Thanks in advance!
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sun, Mar 20 2016 2:25 PM
steve1977:
YES, with Twonky as intermediate (some issues though; see this site)
steve1977:
YES
steve1977:
There is no auto sensing on the line-in of a NL/ML converter (BLC) (as far as I know and experienced). But you can start the line-in of the BLC without starting the BV5 (depends on setup)
steve1977
Posts 911
steve1977 replied on Sun, Mar 20 2016 2:39 PM
Thanks for your message.
re 1 - also works without twonky? I prefer not to have a dlna server in between. Can the Beomusic app directly access the itunes library with playlists?
re 3 - not sure I understand. When I play to the ML/NL converter (BV5 is turned off), will it output to my Beolabs that are connected to the BV?
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sun, Mar 20 2016 3:02 PM
steve1977:
There must be Twonky in between to work
steve1977:
If the speakers are connected to the BV5, the BV5 will switch on. But it will do the same as if a ML audio master is connected to the BV5; presumably it will blacken the screen
Page 1 of 1 (4 items) | RSS
