What Are You Working On Now
This post has 1,308 Replies | 20 Followers
Christian Christensen
Stockholm
Posts 512
Hahaha,  yes, its combination of scraping of mess with a thin screwdriver, black mess that gets all over my fingers nomatter how i try to becareful, and then washing..very time consuming
My re-capped M75 are my precious diamonds.
Orava
Finland
Posts 991
Orava replied on Sun, Nov 17 2013 9:48 AM
Witch one should be better?
CDM12IND (newer? from Overture), no top rail at all, not even polished slide.
VAU1253 (older? from 9300) decent rails at both sides.
Menahem Yachad
Jerusalem, Israel
Posts 1,249
Buy the EXACT same unit that is installed in there.
This is my favorite laser supplier - tell him I referred you.
http://www.ersatzteil.justone-schnepel.de/html/philips_cdm12_4_vam1204_cdm124.html
Menahem
Orava
Finland
Posts 991
Orava replied on Sun, Nov 17 2013 10:22 AM
Menahem Yachad:
Menahem
Laser unit itself is exactly same, only chassis is different.
ivos
Česká republika
Posts 4
ivos replied on Sun, Nov 17 2013 10:44 AM
Ivo.
Hello, i´ve got a beomaster 3500. Sound is pretty good, and i´m probably one of few people in cze who got this. It´s from Austria´s dump. Repairman couldn´t trust his eyes so he had to open a bottle :).I believe today It´s rare peace of history. Unfortunetly turntable on top is missing which is too pitty. I replaced it by wooden desk and now is tuner as new. It works for twelve years and i´m satisfied with that. I´m looking for Your replys. Bye guys :)
BO
Halmstad, Sweden
Posts 728
BO replied on Sun, Nov 17 2013 11:15 AM
I think VAU1253 is CDPRO which is newer than CDM12 ind..
//Bo.
A long list...
Leslie
the Netherlands City
Posts 5,423
Silver Member
Leslie replied on Sun, Nov 17 2013 11:38 AM
ivos:
Ahoj,mám beomaster 3500. hraje moc hezky,jsem asi jediný z české republiky kdo ho má. Získal jsem ho v Rakousku na skládce. Jsem příznivec starých kousku a tak jsem ho zachránil. Nic mu nebylo a opravář,který mi ho okouknul,než jsem ho uvedl do provozu byl unešený tou precizní prací a na to rozdělal flašku  s kořalkou. Bohužel jsem ale nezachránil navrchu gramofon ,což mě moc mrzí. Namísto něj jsem nahradil deskou celé opláštění a stroj je jako nový ale jen jako tuner. Jsem s ním moc spokojený mám ho už 12 let . Všechny vás zdravím a těším se na příspěvky. Ahoj Ivo.
Right, I can read Beomaster 3500 but that's it :-)
Brengen & Ophalen
Menahem Yachad
Jerusalem, Israel
Posts 1,249
Newer is NOT always better.
And unless you have time and money to waste on experiments, which do not always work out OK, it is best to use the absolute original part, if if is still available.
Of course, when the original part becomes NLA, that is a good time to do experiments.
ivos
Česká republika
Posts 4
ivos replied on Sun, Nov 17 2013 12:13 PM
ivos
Česká republika
Posts 4
ivos replied on Sun, Nov 17 2013 12:20 PM
now is language barrier broken... i hope :)
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sun, Nov 17 2013 1:05 PM
Beocenter 3500 without the record deck.
Orava
Finland
Posts 991
Orava replied on Sun, Nov 17 2013 1:51 PM
BO:
Thats possible, I just think that my 9300 is older that that Ouverture.
Orava
Finland
Posts 991
Orava replied on Sun, Nov 17 2013 1:56 PM
Menahem Yachad:
It seems that newer is seldom better than older, at least in parts so close each other.... Newer is more cost effective to do... Well, as I said laser pick-up unit is 1 to 1, only alu chassis is different.
Orava
Finland
Posts 991
Orava replied on Wed, Nov 20 2013 3:45 PM
Quick question. What and how much I should give to beolab or similar through powerlink to wake it up?
tournedos
Finland
Posts 7,357
tournedos replied on Wed, Nov 20 2013 5:03 PM
Orava:
Five volts (or thereabouts, it's not critical) should do it. It needs very little current drive, for example in a Beolab 8000 the PL power on signal (pin 4) is terminated into a 33 kohm series resistor and then 10 kohms parallel to the ground before the signal goes to the base of an NPN transistor, so less than 0.2 mA should be enough.
--mika
Orava
Finland
Posts 991
Orava replied on Wed, Nov 20 2013 6:06 PM
Ok, thanks
Peter the Biker
Eastwestfalia
Posts 944
ivos:
Ivo.
And how many times did you comment a bad movie using one of the tools on the left hand side of your TV-set? Confused
Peter the biker
Orava
Finland
Posts 991
Orava replied on Thu, Nov 21 2013 3:39 PM
In ouverture CD is held with these coilsprings, one each side.
Belive me, if you lost grip when inserting it, it diissapears in inners of device faster than speed of light
Orava
Finland
Posts 991
Orava replied on Thu, Nov 21 2013 3:42 PM
I was wondering why the heck this shuts itself off immedially after switched on by beomaster
can you guess why ?
RaMaBo
near Munich
Posts 626
RaMaBo replied on Thu, Nov 21 2013 4:05 PM
could be the overload protection. I had a MCL 2P where i changed the NTC (mounted on the heatsink, connected with two cables to the mainboard.
It measured fine about 330K at around 25 degree Celcius but was somehow defect. Tried to get another one but it was nearly impossible. Finally i found a 300K NTC which worked fine.
Could also be the Hybrid Chip giving to much DC at the output Pin.
Ralph-Marcus
Orava
Finland
Posts 991
Orava replied on Fri, Nov 22 2013 6:56 AM
aaa, nothing that dramatic actually, those were things did came to my mind also.
But this is tricky... Wink
Leslie
Posts 5,423
Silver Member
Leslie replied on Sun, Nov 24 2013 1:22 PM
My Beocord 2200 finished and its working smoothly.
Got "test" belts from Martin for free and it runs like hell, thanks Martin!Yes - thumbs up
Next restoration is a BM3400. Repaired by member Ipaul and my task is to make it as new againWhistle
Brengen & Ophalen
Menahem Yachad
Jerusalem, Israel
Posts 1,249
Leslie
You're touching my heart there Broken Heart.
That was my first ever BeoSystem in 1976 - BeoMaster 3400, BeoGram 3400 (with CD-4 PCB), BeoCord 2200. I saved for over a year, until I could proudly walk into the dealer, and tell him "Here, I can take them home now!"
I still have the BM3400 ond BC2200, but I stupidly sold the BG3400 about 10 years ago, when I lusted after a BG4000.
There's lot's to do on the BM3400 if you want it audiophile quality!
Menahem
Leslie
Posts 5,423
Silver Member
Leslie replied on Sun, Nov 24 2013 3:48 PM
Menahem Yachad:
Really Menahem? Happy to hear Right Hug
Menahem Yachad:
Meaning? Some caps have already been replaced, not all of them. Have to ask Ipaul. Can't wait till it's finished, just for the looks.
Now on the search for a BM3400 quad. You think I can connect my BG6000 quad to this beauty?
Brengen & Ophalen
Menahem Yachad
Jerusalem, Israel
Posts 1,249
The BM3400 and the BG6000 fit together PERFECTLY!
I have restored many BG6000's, and I believe there is no better RIAA pre-amp anywhere, than that which is on the CD4 circuit of the BG6000 PCB.
If IPaul is serious about his BM3400, he should contact me, not only capacitors, but many mods to resistors, diodes and the circuits.
Orava
Finland
Posts 991
Orava replied on Sun, Nov 24 2013 4:24 PM
Orava:
can you guess why ?
No one? Notice position of amp, it lies on bench face down, AND that tiny off in lowwer left corner switch is towards bench and so constantly activated! Surprise
How stupid one can be ???!!! CryingCryingCrying
Menahem Yachad
Jerusalem, Israel
Posts 1,249
It happens to me once in a while - it's not about you being stupid, it's about bad engineering.
There is a lot of equipment made in which it's obvious that the design suits ease of initial assembly, but no consideration given to the complexity of disassembly / maintenance after the sale.
I normally scan (with my eyes) all control panels before turning them over to lie inverted on my workbench, for any protrusions (like your switch) - it saves having to repair later - just a habit learnt by bitter experience!!!
BO
Halmstad, Sweden
Posts 728
Finally iv'e finished the restoration of my second pair of Beolab Penta MKII. I was nearly done  several month ago when i dropped one of the amplifiers on the concrete floor in my workshop. The amplifier was powered when it happened and among two shortened output transistors the min pcb was broken with several traces cracked. It took me some month to get into the right mood to repair the thing. Now efter several hour of fault finding it working again.
Now connected with my BC9500 together with my second pair. All four Pentas have been refoamed, recapped crossovers, new audioclass OP's and foil caps in the signal path. The sound is mighty!
//Bo.
A long list...
Rich
Orlando, Florida, USA
Posts 2,598
Rich replied on Tue, Nov 26 2013 9:12 PM
Lovely room.
Orava
Finland
Posts 991
Orava replied on Sat, Nov 30 2013 1:55 PM
Sometimes it makes you wonder, is it worth of it.....
Orava
Finland
Posts 991
Orava replied on Mon, Dec 2 2013 3:51 PM
This apparat makes me wonder, what if B&O has made upright recordplayer, what is would look like? Ouverture with recordplayer instead of CD? Revox style arm behind diskclamp?
Leslie
Posts 5,423
Silver Member
Leslie replied on Wed, Dec 4 2013 10:57 PM
My Beovox RL7000 to be reclothed...
Brengen & Ophalen
John Francis
USA
Posts 155
Silver Member
This is directed to Leslie and slightly off topic here, but I believe he mentioned having replaced the typography on various pieces of equipment. How do you have that made, is it a decal? And how do you remove the worn or partially removed old type that might be left on the equipment before applying the new type. I was trying to paint the backside of the aluminum door that goes over the sensor and tone arms of a BG 8000 and when I took the tape off part of the type on the black anodized surface came off with the tape.
John
Søren Mexico
Mexico City
Posts 6,411
jfrancis:
Well, also a little of topic, but made Xmas cookies (Vanille kranse) and some of them turned out like this
sonavor
Texas, United States
Posts 3,732
sonavor replied on Sat, Dec 7 2013 5:40 AM
That is your subconscious telling you to begin your next project.
Leslie
Posts 5,423
Silver Member
Leslie replied on Sun, Dec 8 2013 10:29 AM
Finished my RL7000, lots of picturesStick out tongue
Brengen & Ophalen
Menahem Yachad
Jerusalem, Israel
Posts 1,249
I think that I finally understand what is going on here - the B&O Museum has run out of space in Struer, so they are expanding to Holland.
Leslie
Posts 5,423
Silver Member
Leslie replied on Sun, Dec 8 2013 11:13 AM
My gosh, you got me Menahem! And there's a lot moreWink
Brengen & Ophalen
Ricardo
Moonbase 5
Posts 418
Ricardo replied on Sun, Dec 8 2013 8:27 PM
Orava:
I have as couple of boxes filled with that
Orava
Finland
Posts 991
Orava replied on Mon, Dec 9 2013 6:54 AM
yeah, but thats something I try to avoid... and put these in their own box in neat order Wink
Page 23 of 33 (1309 items) « First ... < Previous 21 22 23 24 25 Next > ... Last » | RSS
DigiCert Secured Site Seal
