Leslie, I hope it will still be there next time I will come to see you ;)
Beautiful job !!!
You've already seen it my friend but that was before refurb!
Brengen & Ophalen
I Know ;) but last week, they were in good condition but now !!!!! They are new !
I think there is something you did not show me ... Your Delorean ;)
Working on a beovision 5, bought it very cheap but ...... needed cleaning and fixing
All cleaned now have to put it back together.
Even with that dirt it was still running, the problem is in the panasonic plasma. Will post pictures.
Someone must have had the BV5 strapped to the front of the suv for the Paris Dakar !
That's a good one! LOL!
But even better - it happens all the time, I get machines in for service, just as dirty, and the customer tells me that it was at another serviceman, who couldn't fix it. Surprise, surprise!
Well, what does that tell me? That the other tech is too cheap to clean his customer's machine before he starts work? Or that he loves working with dirty equipment?
So, an air compressor is as basic a tool as a screwdriver, in any professional workshop.
I insist on a completely clean machine before I start working on it, and only a compressor can do the job properly.
Even if there was no fan to suck in all that dust, the warm electronics provide a very comfortable home for many little (and sometimes big) bugs, whose decomposed parts can be seen flying out every which way, when the compressed air does its job.
What to do if your covers are broken, missing or you don't like the ugly yellow ones for Penta MkII.
I wanted something that would look good on my Pentas with black cloth and black plastic.
//Bo.A long list...
Again good job Bo, you're like me looking for alternatives
Proof again, that we have some very talented people here!!!
Thanks Menahem, just a matter of improvising!
What Menahem said.
Menahem Yachad: Even if there was no fan to suck in all that dust, the warm electronics provide a very comfortable home for many little (and sometimes big) bugs, whose decomposed parts can be seen flying out every which way, when the compressed air does its job.
Bugs!? I thought bugs were mostly on digital...? On Programs...?
Super nice, such a nice work !, Bo
My re-capped M75 are my precious diamonds.
Orava:Bugs!? I thought bugs were mostly on digital...? On Programs...?
Merry go round... the first documented computer bug actually was a bug - a moth in a relay in 1947, debugged by Lt. Grace Hopper of US Navy
--mika
Rare!
jfrancis:This is directed to Leslie and slightly off topic here, but I believe he mentioned having replaced the typography on various pieces of equipment. How do you have that made, is it a decal? And how do you remove the worn or partially removed old type that might be left on the equipment before applying the new type.
Sorry John for this late reply! Decal means rub off lettering? Yes if you saw my thread for the Bang & Olufsen text on my Beolabs3000/4500/5000.
The original text which was on the Beolabs is also sort of decal and not engraved!
jfrancis: I was trying to paint the backside of the aluminum door that goes over the sensor and tone arms of a BG 8000 and when I took the tape off part of the type on the black anodized surface came off with the tape.
Use the proper double side sticky tape and clean the surface thoroughly or use some sanding paper?
Luckyly I didn´t have to yet :D. It´s just a model :). It would be illegal here :)
Two sided black epoxy
No one will ever know
That it's reglued
And another CX100 saved from the dumpyard, refoamed and reclothed! Next job, white Cona, perfect match!
how do you do the re-lettering ?
Christian
Is this question meant for me Christian and if yes do you mean the lettering on the Beolabs flatpanels?
Absolutely no trace from gluing, very convenient, one go, no painting, just clean and glue.
Lesslie, no I pushed quick reply on Chartz re-lettering on the Beolab 5000.Wondering how you do it.
That's okay. Coincidence that I have to do the same thing with one of my classic Beolab 5000's. Just waiting for the decal sheets.
Leslie, is it decal sheets the old way, you hold the decal twoards and rub with a pen ?, is it diffuclt to find a decalsheet with the font ?
Yes Christian, it is. Will show you LOP's lots of pictures soon. Received my decals today.
First of all I would like to apologize for using the word LOP's which could be misunderstood by the English spoken ones. A kind member informed me about that. For your information I was using that abbreviation as Lots Of Pictures.
Ok, back to the lettering on my Beolab 5000.
Almost finished but need to put some transparent lacquer to finish it.
Got my 3rd set classic Beolab/Master 5000 which one of my BW friends Jacques brought for me from Belgium and it is in full working condition.
The font type is not exactly the same and slightly bigger, Helvetica 4.3 than (then) the original one.
Sliders (yellow) have been cleaned by putting it in a bowl of dish wash soap (few days) and it looks much better now.
Leslie, when I brought you this amp, it was perfectly sounding but had a major failure... this panel !!!! To be honnest with you, I was'nt sureyou will be able to fix it. But everything seems to be so easy ;) I admire your patience and your attention to details !!!
Now, you will need to find space for the speakers (beovox 5000) ;)
Thanks Jacques, this evening I will finish the Beolab 5000 and start working on the Beomaster 5000.
Hi Leslie!
Remember I did the same on the Beomaster 5000 tuner that you sold me two or three years ago?
I also did the slider.
Jacques
Looks great Jacques, I remember that this was one of your first posts on this thread. To be honest, I noticed that you have been using the same font type. For me it was a coincidence buying the decal sheet. It looks the same only the fontsize is slightly bigger (.3mm) as the original one.
chartz: Hi
Hi
Stunning! I almost wish I had a need to refurbish the lettering on my units. Unfortunatly I dont... 😎
http://tinyurl.com/qj9cjsf
"Stunning" is an understatement!
I was cured alright!
Jeff
Searching with cats ans dogs
Loose ground link making CD mech nuts, tiny trace of smoke gave it away.
Hi Leslie
Where do you get the cloth...
I have a lot of these to rebuilt but where do you guys find all these cloth. Are you using socks or women stockings.
Depends what type of speakers you want to recloth?
Jacquesboo:Now, you will need to find space for the speakers (beovox 5000) ;)
Sold them a while ago Jacques :-)
Doing some serious cleaning and refoaming. I did clean them and not recloth.
