Old thread resurrection
the Playmaker is cheap second hand. Will it provide better sound quality than an airport express?
Beosound 8, Beotime, Beocom 4, Beo 5, Lutron Rania, MacBook 15" (Mid 2015), iPad Pro, iPhone 6S, B&O Play H3, Beolit 12, Form 2, A8 Headphones, B&O Play A1, B&O Essence
Chris Harrison:Old thread resurrection the Playmaker is cheap second hand. Will it provide better sound quality than an airport express? Beosound 8, Beotime, Beocom 4, Beo 5, Lutron Rania, MacBook 15" (Mid 2015), iPad Mini, iPhone 6, B&O Play H3, Beolit 12, Form 2, A8 Headphones.
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
And more functionality - extra input, sound and playback control.
My options are:Sonos, Essence or Playmaker. What are the disadvantages of the Playmaker? The Playmaker is much cheaper.
Mine's a Mk1, but apparently the Mk2 Playmaker doesn't do FLAC.
I’ve been told to avoid the playmaker and go for a essence, it’s much more expensive. What are the differences?
What do you want to compare?
Playmaker and the Essence (1st gen/MK1) or the Essence (2nd gen/MK2)?
...and what are your expectations, what do you want it to do?
Chris Harrison:My options are: Sonos, Essence or Playmaker.
If one of your option isn't B&O made, why limit them to Sonos ?
Chromecast, Samsung LinkMate, etc. are also able to do the job...
Have a look here : http://www.qobuz.com/gb-en/info/-MAGAZINE-HIFI297?page=1
