How do you check on what version of Beo4 you have ?
This post has 20 Replies | 1 Follower
elephant
AU
Posts 8,219
elephant Posted: Wed, Jul 11 2012 6:54 PM
I thought my Beo4s were equal - now I am struggling to find [DTV2] on one of them.
  1. Is there a Beo4 service command string that reveals the Beo4's software level etc ?
  2. Alternatively, is there a hidden key sequence that magically adds [DTV2] to the list ?
(and yes, I know DTV2 seems some how to map to VAUX but I am chasing the answers to 1, or 2, or both Smile)
Thanks.
BeoNut since '75
Paul W
London
Posts 1,810
Paul W replied on Wed, Jul 11 2012 7:03 PM
Strangely, my first Beo4 from 1999 is a far nicer metal material than my 2005 BV6 and all of the latest ones. I wonder why they changed the material used?
tournedos
Finland
Posts 7,357
tournedos replied on Wed, Jul 11 2012 7:04 PM
  1. GO+MENU at the same time; then LIST through the displays.
  2. No. I think it's there starting from SW 6.22.
--mika
Chris Townsend
Qatar
Posts 3,531
personaltrainerpaul:
Of all my gear, the Beo 4 is the one piece I don't consider there is a better device to be had. And i already own a Beo 6(which sits in it's cradle waiting to fall over and break)
elephant
AU
Posts 8,219
elephant replied on Wed, Jul 11 2012 10:00 PM
tournedos:
Thanks !
  1. Did that and it worked showing EE 6,1 and SW 5,0 on both units
  2. SW 6.2 ?
    Now I am confused Smile
    Is EE and SW combined the indication of level ?
    Or if it is SW only and your SW 6,22 is correct, how did [DTV2] get on to only one of them ?
BeoNut since '75
Paul W
London
Posts 1,810
Paul W replied on Wed, Jul 11 2012 11:46 PM
I agree Chris, the Beo4 is the world's best remote control!!! Just perfect in every way! The Beo5/6 truly sucks!  Beo4 simply incredible, iconic and does what it says on the tin!
Vienna
make an educated guess
Posts 1,090
Vienna replied on Thu, Jul 12 2012 1:34 AM
elephant:
  2. SW 6.2 ?
Very likely they have a different "Video-Config"
= Set of names for the same IR commands that fit to different (older/newer) TVs.
STDBY + LIST > >> LIST till CONFIG? > GO > VIDEO? > GO > LIST till VIDEO 4 is displayed > GO
Verified on my oldest Beo4 displaying EE:6.2 / SW:5.0 / VIDEO4 / AUDIO 1
"LIST" is offering both  - "V.AUX" as well as "DTV2"
Steffen
Denmark
Posts 1,408
Steffen replied on Thu, Jul 12 2012 1:51 AM
Paul W:
Have they changed the materials on the Beo4? Huh?
I have had all of the Beo4's, except the latest version. I must say that I haven't noticed any changes in the materials...
Unfortunately I no longer have the Mk 1 to do a comparison...but the 3 Beo4's I have now looks and feels quite alike (except from the buttons, offcourse).
Jonathan
Melbourne, Australia
Posts 1,811
Jonathan replied on Thu, Jul 12 2012 2:34 AM
Steffen:
Paul W:
I have them all (Mark 1,2,3 and 4) and they're all made from the same materials.....
x:________________________
elephant
AU
Posts 8,219
elephant replied on Thu, Jul 12 2012 9:00 AM
Jonathan:
Steffen:
Paul W:
We handled the new (joystick) Beo4 last weekend at the dealer in Collins Street - to me the underneath has a new texture and feel to it - perhaps it will age over time, but it felt quite different; and Sue said she thought it felt lighter than ours at home
BeoNut since '75
Mindphaser
Posts 100
Chris Townsend:
Cannot quote enough.
For me; especially for materials used and for 'look and feel', BEO4 is the best remote command ever made.
I tried a BeO5 from a friend of mine;but it seemed to me way 'cheaper' than BEO4; i mean it looked like a gadget ...you would thought that BeO5 could be make in China or whatever, BEO4 is so firm and  solid that you would NEVER thought that Smile
elephant
AU
Posts 8,219
elephant replied on Thu, Jul 12 2012 9:48 AM
Vienna:
elephant:
  2. SW 6.2 ?
Thanks Vienna - your advice and details are always so accurate.
My two Beo 4s are:
  • VIDEO 1
  • AUDIO 1
  • EE 6.1
  • SW 5.0
However there is a distinct difference when I step through ADD? LIST LIST LIST comparing their "features"
The one which has DTV2 also has P-DTV2, L-DTV2 et cetera; and of course VAUX.
The other one has NO DTV2s at all.
As you can expect, looking at two Beo4s and pressing
  1. LIST, LIST compare
  2. LIST, LIST compare
  3. LIST, LIST compare
  4. LIST, LIST compare
  5. et cetera
is very time consuming, boring, and incredibly irritating when the two lists get out of order because at different times they have had different things ADDed, REMOVEd and MOVEd !
But I will eventually find what is added and/or replaced and/or missing .......... even though it is largely an academic exercise !
BeoNut since '75
Vienna
Posts 1,090
Vienna replied on Thu, Jul 12 2012 10:12 AM
elephant:
Just a guess, maybe the other Beo4 has previously been in an other video-config than "video1" and is
therefore still "remembering" the set of DTV2 commands ...
Big Smile ...  on the Beo 4 w/o "DTV2" try a change of the config for  video to a different version ( video 2 / 3 / 4)
and check if "DTV2"  appears in the "LIST" ...
elephant
AU
Posts 8,219
elephant replied on Thu, Jul 12 2012 11:15 AM
Vienna:
elephant:
Yes, I had a similar thought - so I took your advice ... first observation is that doing this wipes the pervious settings !  Secondly since you mentioned you had VIDEO = 4 I tried that first ....
  • VIDEO = 4 ... no DTV2
  • VIDEO = 3 ... no DTV2
  • VIDEO = 2 ... no DTV2
hmmm, what do this different video options do ?
BeoNut since '75
Vienna
Posts 1,090
Vienna replied on Thu, Jul 12 2012 1:10 PM
elephant:
... hmmm, what do this different video options do ?
"History" compatibility =  Change of "displayed name" in the "LIST" for the same IR commands
(to better fit to different older/newer TVs).
Adding / removing "special commands" needed only for some types of TVs
PS:  My Beo4 is EE:6.2  - that may explain the difference
        but you say, both of your Beo4s are EE 6.1 and only one has DTV2 ! - I'm also Confused
Paul W
London
Posts 1,810
Paul W replied on Thu, Jul 12 2012 1:32 PM
They HAVE definitely changed the side of the Beo4 material! It's hard to describe, but the 1999 model does feel a better quality. It's a smoother feeling material.
Vienna
Posts 1,090
Vienna replied on Thu, Jul 12 2012 3:03 PM
elephant:
Video1: Avant Chassis and MX 4/6/7000
Video2: BV/BC 1 and MX 8000
Video3: USA Versions
Audio1: Basic Audio Setup
Audio2: BS9000
DTV2 has been introduced in SW EE:6.22
To make things a bit more complicated there have been 4 versions of 6.22
regarding the "ex factoryt" setup.
Video1/Audio1: EE:6.19
Video2/Audio1: EE:6.20
Video3/Audio2: EE:6.21
Video4/Audio1: EE:6.22
Very likely one of your Beo4s is a EE:6.19 version = EE:6.22 version in ex factory setup Video1/Audio1,
the other one seems to be a "real" EE:6.1 version
ADDED in EE:6.22:
DTV2
P-DTV2
L-DTV2
A-DTV2
REMOVED in EE:6.22:
REC LOCK
REC UNLOCK
elephant
AU
Posts 8,219
elephant replied on Thu, Jul 12 2012 4:22 PM
Vienna:
elephant:
Audio2: BS9000
DTV2 has been introduced in SW 6.22
Video1/Audio1: 6.19
Video2/Audio1: 6.20
Video3/Audio2: 6.21
Video4/Audio1: 6.22
Very likely one of your Beo4s is a 6.19 version = 6.22 version in ex factory setup Video1/Audio1,
the other one seems to be a "real" 6.1 version
ADDED in 6.22:
DTV2
P-DTV2
L-DTV2
A-DTV2
REMOVED in 6.22:
REC LOCK
REC UNLOCK
I think we are getting close Smile
Clearly my BV8 environment should not be using VIDEO=1 but (by default/exception from you list) VIDEO=4
And unit B that shows DTV2 does NOT have LOCK and does NOT have UNLOCK
Whereas unit A that does NOT have DTV2 does have both
However setting both units to VIDEO=4 did not change the SW level repeat did not change either unit, it still shows as 5.0 Sad
And of course did wipe the configured lists on both units Crying
So I have now configured the two Beo4s to have identical LISTs
Thanks again Vienna for your help - I think we will never get to the bottom of the mystery of SW but I think your supposition is correct
Come the weekend I will focus on why the LinkPlayer V2 beta works better with a BV8-32 than with a BV8-40 Confused
BeoNut since '75
Vienna
Posts 1,090
Vienna replied on Thu, Jul 12 2012 4:48 PM
elephant:
... I think we will never get to the bottom of the mystery of SW...
Big Smile Dear friend, in this SPECIFIC CASE i think we GOT TO THE BOTTOM of SW MYSTERY
If EE:6.22 in Video1/Audio1 = EE:6.19 and you read only 1 decimal then EE:6.22 = EE:6.1 - LOL
PS: All of these EE versions run on SW 5.0
Steffen
Denmark
Posts 1,408
Steffen replied on Thu, Jul 12 2012 10:05 PM
Paul W:
Ok -they may have changed the coating/paint. But the 'body' is still made of zinc - just like the old Beolink 1000.
elephant
AU
Posts 8,219
elephant replied on Thu, Jul 12 2012 10:58 PM
Vienna:
elephant:
*doh* you are so right
the letters run from one edge to the other on the Beo4's display: [EE:  6.1]
the space between the ":" and the "6" was enough to hide the missing "9"
BeoNut since '75
Page 1 of 1 (21 items) | RSS
