LCS9000 and Beolab 3500 differences
This post has 11 Replies | 2 Followers
akapur
Posts 4
akapur Posted: Fri, Jul 13 2012 5:20 PM
Hi -
New to this forum - and looking forward to being part of the community.
Need some guidance and hoping the community can help.  I have a Beosound 9000 + Beloab 6000 set up.  I also have a beolink set up in a different room with a set of speakers as well.
I want to set up a Beolab 3500 in the kitchen and I have been looking in the market to buy one.  I found a model for sale, but it is a LCS 9000 which is the older version.  Does anyone know what the major differences are between the two models and if the LCS9000 would work in my setup.
Thanks in advance.
KingOfSnake
Posts 162
Pretty sure the LCS9000 needed an upgrade for the ML socket to work, unless you use with an MCL converter of some sort.
My understanding has always been that the LCS9000 was MCL (Master Control Link) based which has a round pin, and that the ML module, although fitted, was not operational.
frog
Camberley UK
Posts 624
frog replied on Sat, Jul 14 2012 1:29 PM
Yes, you would potentially need a software update to turn it into a 3500. This involves a pretty simple procedure to replace the microcomputer module in the lcs9000. The part is available from B&O but check that the unit hasn't already been upgraded. The service manual explains how to get access to the engineering menus to find out what version the microcomputer actually is. I think the latest is v2.1 which supports Internet radio and music.
Keith Saunders
Hampshire, United Kingdom
Posts 5,495
KingOfSnake:
The LCS9000 was released with version 1.1 software and the MCL port enabled. The Masterlink socket had a black cap over the socket which when removed could be used without a software update by switching it over using the following command:-
To get into the service menu to switch between ML & MCL press MENU then MENU then 0 then 2 then PLAY, then use the up arrow to switch, then store.
Regards Keith....
akapur
Posts 4
akapur replied on Fri, Jul 27 2012 5:39 AM
Keith -
I tried what you suggested and it didn't work. Could it be because I have a Beo4 remote instead of a Beolink 1000?
Keith Saunders
Posts 5,495
akapur:
Keith -
Yes, my instructions did assume a Beolink 1000, but you can still do it with a Beo4.
Regards Keith....
Keith Saunders
Posts 5,495
akapur:
When the LCS9000 was released it had version 1.1 software and at that time it was sold with the MCL (Master Control Link) enabled.
Subsequently, the LCS9000 was renamed as the Beolab 3500 with the ML (MasterLink) enabled, still with version 1.1 software. So from a functionality viewpoint that were and are exactly the same.
Some years later version 2.1 software was release which allowed the Beolab 3500 to display N.Music and N.Radio.
So, if you buy a LCS9000 today, it will work on a MasterLink network provided Masterlink is enabled as shown below..
Regards Keith....
mariuszf1
Spain
Posts 12
Hi Keith, just read this thread and wondering if the powerlink plug can be used for direct connection i.e. to use the BL 3500 as center  speaker connected directly to BS3. thanks in advance.
Kind regards
Mariusz
kelsan
Posts 7
kelsan replied on Mon, Mar 2 2020 3:13 PM
Can you give instructions on how to change to Masterlink with Beo4?
dahiyas
United States
Posts 145
Silver Member
dahiyas replied on Tue, Mar 3 2020 3:56 AM
MENU 0 9 UP(above go button)
GO
Display should show ML ON.
kelsan
Posts 7
kelsan replied on Sat, Mar 7 2020 11:43 AM
Sorry, but it did not work.
I assume that it is a sequence of buttons or should they be pressed together?
Keld
dahiyas
United States
Posts 145
Silver Member
dahiyas replied on Sun, Mar 8 2020 4:48 AM
Sequence of buttons.
Page 1 of 1 (12 items) | RSS
DigiCert Secured Site Seal
