Eclipse 65V1-32Beosound M5Essence MK2BLI
Hi Seanie,
I can't remember how flat the underside of the BLGW is, but if there's enough of it that would be in contact with the wall you could consider using heavy duty velcro strips.
http://www.amazon.co.uk/Velcro-Heavy-Duty-Strips-50x100mm-VEL60239/dp/B001786DAK
Martin.
Seanie_230:Does anyone know the RRP of the proper bracket ?
The NL/ML converter wall bracket is aound 20GBP if I remember correctly and I would assume the same bracket is used for the BLGW since the two units are physically identical.
