Wall mount BLGW
This post has 3 Replies | 2 Followers
Seanie_230
UK
Posts 2,278
Seanie_230 Posted: Sat, Mar 26 2016 3:09 PM
Hello all
Has anyone got any good ideas how to wall mount the Beolink Gateway without having to buy the bracket today?
Is there another way?
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Sat, Mar 26 2016 5:17 PM
Hi Seanie,
I can't remember how flat the underside of the BLGW is, but if there's enough of it that would be in contact with the wall you could consider using heavy duty velcro strips.
http://www.amazon.co.uk/Velcro-Heavy-Duty-Strips-50x100mm-VEL60239/dp/B001786DAK
Martin.
Seanie_230
UK
Posts 2,278
What a great idea that has sparked an alternative.
I will create some straps to hold it in place rather than Velcro it together.
Does anyone know the RRP of the proper bracket ?
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Sat, Mar 26 2016 10:22 PM
Seanie_230:
The NL/ML converter wall bracket is aound 20GBP if I remember correctly and I would assume the same bracket is used for the BLGW since the two units are physically identical.
Martin.
Page 1 of 1 (4 items) | RSS
