Hello
I would like to purchase the correct light bulbs for the Beomaster 1000. Does anyone know the correct specifications or where to buy them? Also the bulb for the stereo-indicator.
Thank you in advance.
Jakob Larsen
Try messaging 'Dillen' (Martin) on this site. He should have the bulbs you require.
Ben
A 24 V bulb for the stereo decoder will be preferable. I killed two 19 V ones in a short while. Or you can alternatively rise the resistor value if it comes to that - actually what I did.
Jacques
The 2 dial lamps are 6,3V 0,3A and the stereo indicator lamp is 19V 0,1A if I am not wrong.
Those lamps can be still found in any better electronic shop.
Regards,
Theomaster
Vintage Bang & Olufsen
