Light bulbs for Beomaster 1000
This post has 3 Replies | 0 Followers
Jakobtl
Posts 2
Jakobtl Posted: Sun, Mar 27 2016 8:47 AM
Hello
I would like to purchase the correct light bulbs for the Beomaster 1000. Does anyone know the correct specifications or where to buy them? Also the bulb for the stereo-indicator.
Thank you in advance.
Jakob Larsen
Ben_S
UK
Posts 631
Ben_S replied on Sat, Apr 9 2016 7:39 PM
Try messaging 'Dillen' (Martin) on this site. He should have the bulbs you require.
Ben
chartz
Burgundy, France
Posts 4,171
chartz replied on Sat, Apr 9 2016 8:57 PM
A 24 V bulb for the stereo decoder will be preferable. I killed two 19 V ones in a short while. Or you can alternatively rise the resistor value if it comes to that - actually what I did.
Jacques
the_o_master
Posts 856
The 2 dial lamps are 6,3V 0,3A and the stereo indicator lamp is 19V 0,1A if I am not wrong.
Those lamps can be still found in any better electronic shop.
Regards,
Theomaster
Vintage Bang & Olufsen
Page 1 of 1 (4 items) | RSS
