Beogram 4000 in nedd of some TLC
gkt
Posts 14
gkt Posted: Thu, Mar 31 2016 5:55 PM
Hello,
I am hoping some experts out there can help me??
I have a Beogram 4000 which has not been in use for some years!
I plugged her in to find she started turning but no sound Sad  then after 5 minutes just stopped!?! it was making a sound like a motor or something.(but no movement on the turntable, Also the original lead has been cut and some interconnects have been attached.. Oh and the perspex lid has to be held up when lifted.This can't be right??
I would really love to get it going once more!
Any advice/help would be really appreciated Smile
Thanks,
Gary.
sonavor
Texas, United States
Posts 3,732
sonavor replied on Thu, Mar 31 2016 7:33 PM
This Beoworld thread and this web site show what is often needed to restore these turntables. Long term storage is not kind to audio equipment. They need regular use. New belts are for certain but there are likely other things.
-sonavor
gkt
Posts 14
gkt replied on Fri, Apr 1 2016 12:01 AM
Hi..
OK great appreciate your advice.Smile
Sounds like it's gonna be a nightmare...
sonavor
Posts 3,732
sonavor replied on Fri, Apr 1 2016 12:14 AM
gkt:
I have restored two Beogram 4000 turntables now. Each was a challenge and took a lot of work but I wouldn't classify them as nightmares by any means. They are great turntables and well worth restoring. If you aren't able to do the work yourself I would recommend finding a qualified restorer (with an emphasis on qualified).
-sonavor
gkt
Posts 14
gkt replied on Fri, Apr 1 2016 12:21 AM
Hi.
Wow ok will take that advice... there seems to be a big following of vintage hi fi in the states?
I shall definitely look into repairing it..too nice to leave gathering dust!
Thanks again.
Gary
beo3000
Posts 109
beo3000 replied on Fri, Apr 1 2016 12:34 AM
best of luck I am restoring a beogram 4000 at the moment , take look at the beolover blog as well as the thread by sonavor you will also need a service manual too, start off clean all the switches (tarnished silver)  and , check the voltage rails.
sonavor
Posts 3,732
sonavor replied on Fri, Apr 1 2016 7:00 AM
gkt:
... there seems to be a big following of vintage hi fi in the states?Gary
I would say all over the free world Smile. If you look at the workshop and beogram repair threads on the Beoworld forum you will see that there are restorations of classic Bang & Olufsen equipment going on in numerous countries. The B&O pieces look great of course and when restored to proper working order, perform wonderfully. There are also certain classic, milestone units and the Beogram 4000 is one of them.
-sonavor
gkt
Posts 14
gkt replied on Fri, Apr 1 2016 5:04 PM
Ok will do thanks...
gkt
Posts 14
gkt replied on Fri, Apr 1 2016 5:06 PM
Wow.. appreciated, a wealth of information already Smile
Page 1 of 1 (9 items) | RSS
