Beogram 6500 light is on permanently
This post has 4 Replies | 0 Followers
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
joeyboygolf Posted: Tue, Apr 19 2016 7:50 PM
The light at the rear of the turntable is on permanently - anyone know why and how to fix??
Regards Graham
tournedos
Finland
Posts 7,357
tournedos replied on Tue, Apr 19 2016 9:28 PM
I believe this problem has been posted on the forum a couple of times before, and the problem was the transistor controlling the bulb had shorted. Worth a look anyway.
--mika
joeyboygolf
Posts 4,188
Thanks for that, you have confirmed my own and Martin's diagnosis.
I ordered some transistors yesterday, lets hope I'm still capable of a bit of soldering.
Regards Graham
joeyboygolf
Posts 4,188
tournedos:
Replaced TR3 (BC337-25) and fault cured.
Thanks for the info
Regards Graham
joeyboygolf
Posts 4,188
tournedos:
The same turntable is inclined to start spinning of it's own accord. Look, no hands!!!
Any one seen this before?
Regards Graham
Page 1 of 1 (5 items) | RSS
