The light at the rear of the turntable is on permanently - anyone know why and how to fix??
Regards Graham
I believe this problem has been posted on the forum a couple of times before, and the problem was the transistor controlling the bulb had shorted. Worth a look anyway.
--mika
Thanks for that, you have confirmed my own and Martin's diagnosis.
I ordered some transistors yesterday, lets hope I'm still capable of a bit of soldering.
tournedos: I believe this problem has been posted on the forum a couple of times before, and the problem was the transistor controlling the bulb had shorted. Worth a look anyway.
Replaced TR3 (BC337-25) and fault cured.
Thanks for the info
The same turntable is inclined to start spinning of it's own accord. Look, no hands!!!
Any one seen this before?
