I have a Beocenter 2 connected to a Beovision 65 via Masterlink. CD and Radio works but If I press DVD nothing happens. Beocenter 2 does not work on DVD mode at all.
Also, is there a way to adjust the contrast of the display?
Any help is welcome!
Thanks in advance.
is your Beocenter 2 a non DVD version?
it is a DVD version....
Yes, recheck all he connections including the scart at the back of the TV and inside the Beocenter socket box.
From recollection the tight connection space in the socket unit makes the scart and other connections quite vulnerable to being twisted sideways or displaced if a cable is accidentally pulled.
Graham
