Beocenter 2 need help
11048437
Posts 71
11048437 Posted: Thu, Apr 21 2016 11:01 PM
I have a Beocenter 2  connected to a Beovision 65 via Masterlink.  CD and Radio works but If I press DVD nothing happens. Beocenter 2 does not work on DVD mode at all.
Also, is there a way to adjust the contrast of the display?
Any help is welcome!
Thanks in advance.
Rob - Danish AV
Melbourne
Posts 376
is your Beocenter 2 a non DVD version?
11048437
Posts 71
11048437 replied on Fri, Apr 22 2016 1:41 AM
it is a DVD version....
Kevin Waldron
Orange County, California
Posts 20
The beocenter 2 is a dual function item. It is both an audio master and a video device. The audio master plays radio and CDs through its own power link speaker connections or through the master link to a television or another audio slave in another room.
The DVD function however plays locally through the SCART/s-video/composite video and RCA stereo/digital audio ports. These connection must be made directly to the TV in order to watch or listen to DVD.
I believe it was set up this way so that someone could watch a DVD in the main room, while someone else could listen to radio (or net radio/net music depending on one's set up) in another.
vikinger
Vestri Kirkjubyr, UK
Posts 5,422
vikinger replied on Sun, Apr 24 2016 2:52 PM
Yes, recheck all he connections including the scart at the back of the TV and inside the Beocenter socket box.
From recollection the tight connection space in the socket unit makes the scart and other connections quite vulnerable to being twisted sideways or displaced if a cable is accidentally pulled.
Graham
Page 1 of 1 (5 items) | RSS
