Pulse Eight Matrix
This post has 32 Replies | 2 Followers
Chris Hassell
London
Posts 396
Chris Hassell Posted: Fri, Apr 22 2016 10:12 PM
My dealer has recommended I have a look at using Matrixes (Matri?!?) from these guys instead of Atlona...
https://www.pulse-eight.com/
Anyone had any experiences with them?
BeoVision Eclipse 55”, Beolab 18s, Beolab 19s, Beosound 1, Beoplay P2, H3, BeoRemote One IR, BeoRemote One BT, Beoplay S8, Beosound Essence MkII, BeoTime
mjmedlo
Posts 922
mjmedlo replied on Sat, Apr 23 2016 12:35 AM
Be sure it's recognized and controllable from B&O.
Do you use a control system? Or just the B&O puc for your connected devices?
Chris Hassell
London
Posts 396
mjmedlo:
Thanks tor the reply. I haven't got it yet. Just started going through what I want so he can start getting a quote together! He said he's used these matrix systems a few times and all the control works fine.
mjmedlo
Posts 922
mjmedlo replied on Sat, Apr 23 2016 9:00 PM
I'm using Atlona and have no complaints.
Any reason you don't want to use Atlona?
ahjrennie
Posts 20
ahjrennie replied on Sat, Apr 23 2016 9:40 PM
I have a pulse 8. Works perfectly. I had one issue with the power connection they swapped it out within 72h. They monitor remotely and my b&o dealer lets me know if there's an issue. They're a small team based in Dorset so service is amazing. So much cheaper than Altona as well.
Chris Hassell
London
Posts 396
Yeah that's basically what my dealer said - they can build bespoke stuff (6 in 2 out for example) and they're cheaper and just as good as Atlona. Good to hear good experiences about them!
mjmedlo
Posts 922
mjmedlo replied on Sun, Apr 24 2016 5:00 AM
ahjrennie:
Does your B&O panel actually change sources, etc?
How do you control the matrix?
stefan
200 miles from Struer
Posts 2,920
stefan replied on Sun, Apr 24 2016 7:21 AM
Seems to be a very interesting product - HDMI CEC , 3D , 4K, contextuel ir, HD baseT, web interface...
can be puc controle as stated by StÜrrock here on Beoworld about 6 months ago.
I'd like to know about the neo  @ahjrennie - thanks.
Stefan
ahjrennie
Posts 20
ahjrennie replied on Sun, Apr 24 2016 6:57 PM
The Pulse 8 Has sources as if you had something directly plugged into the TV. It switches sources from the beoremote 1 and even BLGW. The source is listed as Matrix 1,2,3,4, e.t.c rather than Virgin TV or Apple TV.
mjmedlo
Posts 922
mjmedlo replied on Sun, Apr 24 2016 6:58 PM
So it works just like an Atlona matrix then?
ahjrennie
Posts 20
ahjrennie replied on Sun, Apr 24 2016 6:59 PM
Hi there, yes indeed the matrix can sense beo remote commands and then send them to the appropriate device attached to the Matrix - through the necessary PUC codes.. Is there anything else you would like to know?
Thanks,
Alex
ahjrennie
Posts 20
ahjrennie replied on Sun, Apr 24 2016 7:00 PM
I've never used an Altona so don't know exactly but it works as you'd expect - seamless distribution of video sources with full ir control.
mjmedlo
Posts 922
mjmedlo replied on Sun, Apr 24 2016 8:10 PM
ahjrennie:
Thanks,
Alex
Does this matrix so source switching?
On the matrix itself?
I.e. Source 4 is aTV and source1 is cable
Can this matrix switch between the boxes AT THE MATRIX.
mjmedlo
Posts 922
mjmedlo replied on Sun, Apr 24 2016 8:13 PM
I dont see it in the B&O PUC database.
stefan
Posts 2,920
stefan replied on Mon, Apr 25 2016 12:51 PM
ahjrennie:
Thanks,
Alex
Thanks for your reply, Alex,
so I`d like to know more details about your setup and the way you use the neo matrix, if you don`t mind...
Which beovisiond do you use in your setup?
Is it a Masterlink- or Netlink setup?
When you control your 3rd party devices via the neo, is it via the Beovisions or via the neo IR receivers?
Do you need the Beo matrix activation key?
Which puc do you use for the matrix, as mjmedio said there is no pulse eight puc in the Beo database.
Do you control the devices by Beo`s source butoons like TV, DVD, V.MEM...? You said, the four sources connected to the neo are listed as Matrix 1,2,3,4. (I assume you have the 4/4 HDbaseTmatrix). What is displayed on the Beovisions, when you select a source?
Sorry, a lot of questions... and thank you again for the kind help!
Stefan
Chris Hassell
London
Posts 396
I'd love to know too Alex if you have time to let us know! Cheers.
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Tue, Apr 26 2016 2:14 AM
stefan:
Hi Stefan,
Just to let you know, in December 2015, Struer decided they would make the HDMI Matrix Feature activation keys available free of charge. You'll just need to ask your dealer and provide them with the model and serial number of your BV.
I'm also interested in further information on how the Neo Matrix works with a BV.
Martin.
riverstyx
SouthWest UK
Posts 938
duplicate deleted
stefan
Posts 2,920
stefan replied on Tue, Apr 26 2016 11:16 AM
Martin, thanks for that information - it`s new to me.
Maybe there are also some members (dealers?), who are able to provide some info, drawings, installation guide, concerning the neo matrix.
StÜrrock already told us in october last year about Pulse Eight.
http://archivedforum2.beoworld.org/forums/p/16884/147323.aspx#147323
Stefan
ahjrennie
Posts 20
ahjrennie replied on Thu, Apr 28 2016 4:28 PM
Hi all - I'll come back to you I've just been a little busy. I'll come back this weekend.
Alex
Chris Hassell
London
Posts 396
Hi @ahjrennie just wondered if you had a chance to tell us more about your Neo Matrix setup?
stefan
Posts 2,920
stefan replied on Sun, May 22 2016 12:18 PM
The Atlona matrix is still the only matrix on Beo`s official supported matrix "list". My dealer had a cal with Beo in Struer while I was in the store, and that`s what they told him.
So it looks like - 1: a dealer created a puc for the Neo matrix (as I heard, dealers can buy the software to create pucs for Beovisions), oR
- 2: Pulse eight use the same ir codes as Atlona...(?!).
Maybe Alex , StÜrrock or someone else can tell us a bit more about it...? - thanks.
Stefan
StUrrock
Posts 995
Switched from Atlona to Pulse Eight matrixes quite some time ago.
Very happy and works extremely well with B&O and other  products.
Great support from the manufacturers (know the MD personally).
Has a web interface, suports CEC for non B&O sets.
In 18 months all customer's very happy.
PM with your email address for more details.
Chris Hassell
London
Posts 396
StUrrock:
Hi @stUrrock thanks for the info. Sounds like what I'll get. Is it controllable via BLGW? Also how controllable via CEC are Sony TVs, do you use CEC at all?
stefan
Posts 2,920
stefan replied on Mon, Jun 6 2016 11:43 AM
StUrrock:
I don`t know what`s the secret about Pulse Eight, but I `ve sent you a pm some time ago...(?)
Stefan
StUrrock
Posts 995
StUrrock replied on Mon, Jun 20 2016 10:41 PM
stefan:
StUrrock:
Stefan
Just noticed my email for PMs doesn't exist anymore. Will change when I get am mo.
Why not just contact Pulse Eight, their exisitance is no secret?
Or you could just rely on the forum slaves to do the research for you Wink
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Mon, Jun 20 2016 11:12 PM
StUrrock:
Hi StUrrock,
I think what I, Stefan, and others are interested in initially are independent opinions on these matrix from those with experience using them in a B&O environment - eg:
1. Do they emulate the atlona commands and thus use one of the Atlona PUCs (if so which one?) or did you have to create a custom PUC?
2. Have you discovered any downsides to deviating away from B&Os supported solution (Atlona)?
3. Are there any differences from either an installer, or end user perspective that we ought to be aware of?
I've no issue with contacting the manufacturer directly for support, but I don't know how familiar they are with B&O so it's the B&O specific stuff I am concerned with initially.
Kind Regards,
Martin.
stefan
Posts 2,920
stefan replied on Tue, Jun 21 2016 2:26 PM
StUrrock:
StUrrock:
...because I`d like to know more about Beointegration of the Neo matrix - and you offered more details via pm.
StUrrock:
I did a lot of research - see my posts above....
Stefan
stefan
Posts 2,920
stefan replied on Tue, Jun 21 2016 2:28 PM
riverstyx:
StUrrock:
Hi StUrrock,
Kind Regards,
Martin.
Exactly - that`s it - thanks Martin!
Stefan
StUrrock
Posts 995
riverstyx:
StUrrock:
In answer to your questions,
1. They listen for the Atlona commands so you can use theStandard Atlona PUC
2. No problems no problems at all.
3. Just to be careful when setting up the product integration settings in the new TVs take it stage by stage and you will have no problems. Why not call Martyn @ Pulse eight (the MD) he is just fab, he will tell you all you need to know and more.
riverstyx
SouthWest UK
Posts 938
StUrrock:
Thanks StUrrock - info much appreciated.
Cheers,
Martin.
PulseEight
Posts 2
Hello all, we've just found this forum, we are here if you have questions, or you can email our support team support@pulse-eight.com if you have questions about our matrixes.
In summary we are a more affordable alternative to Atlona, we have remote diagnostics, so we can provide your installer (and you) with health information on the cables, connected devices and the matrix.
We are able to control devices from our smartphone/web app and we also link in with Amazon Alexa, so you can say things like "Alexa, turn on Sky Q on lounge" and we will switch the channel for you. You can even say "Alexa, change channel to BBC one" to change to 101 without picking up the remote.
Hope this is helpful!
Guy
Warwickshire
Posts 2,590
Guy replied on Sat, Jul 15 2017 10:49 AM
PulseEight:
I just had a look at your website.  Do any of your products eliminate the hdcp from the hdmi output?  (Not by design, but as an added bonus perhaps?)
Page 1 of 1 (33 items) | RSS
