3D Glasses
This post has 5 Replies | 2 Followers
Seanie_230
UK
Posts 2,278
Seanie_230 Posted: Mon, Apr 25 2016 7:07 AM
Good morning Beoteam
I have four pairs of 3D glasses for my BV7 and they either sit on the side in a mess or in a draw.
Is there such thing as a charging dock that holds four pairs perhaps ?
Like the PlayStation controller dock?
Thank you
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
steve1977
Posts 911
steve1977 replied on Wed, Apr 27 2016 4:25 AM
I would also be very interested. any ideas?
Seanie_230
UK
Posts 2,278
Anyone tried a wireless stand?
Do we know what make the glasses really are?
https://www.amazon.co.uk/Samsung-CY-SWC1000A-Glasses-Wireless-Charger/dp/B004TB51HS
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Michael
Sweden
Posts 2,578
Michael replied on Mon, May 2 2016 3:05 PM
Seanie_230:
They are made by Xpand and I believe the glasses from B&O uses a custom firmware compared to the retail glasses from Xpand. They look exactly like these http://www.amazon.com/X105-IR-X1-Rechargeable-Infrared-Multibrand-Glasses/dp/B00BFO4XTO.
I have two pairs of the B&O edition glasses, can take a closer look at home.
However - you won't be able to charge them wirelessly, you need a micro usb cable to charge them, which is easy enough I think. I don't use them very often.
I am a bit curious about how to replace the batteries when they wear out, they seem to be a part of the glasses - not meant to be user replaced.
steve1977
Posts 911
Thanks. We were looking for some nicer way to store the glasses when charging. When just using a USB cable, they will just lie around. Has anyone seen some nicer charging solution that can be used for these glasses?
Michael
Sweden
Posts 2,578
Michael replied on Wed, May 4 2016 2:11 PM
steve1977:
I just charge my glasses when necessary and not when they are idle. Just put the cables in a small box and you have a solution :)
Page 1 of 1 (6 items) | RSS
