Eclipse 65V1-32Beosound M5Essence MK2BLI
Seanie_230:Anyone tried a wireless stand? Do we know what make the glasses really are? https://www.amazon.co.uk/Samsung-CY-SWC1000A-Glasses-Wireless-Charger/dp/B004TB51HS
They are made by Xpand and I believe the glasses from B&O uses a custom firmware compared to the retail glasses from Xpand. They look exactly like these http://www.amazon.com/X105-IR-X1-Rechargeable-Infrared-Multibrand-Glasses/dp/B00BFO4XTO.I have two pairs of the B&O edition glasses, can take a closer look at home. However - you won't be able to charge them wirelessly, you need a micro usb cable to charge them, which is easy enough I think. I don't use them very often.I am a bit curious about how to replace the batteries when they wear out, they seem to be a part of the glasses - not meant to be user replaced.
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
Thanks. We were looking for some nicer way to store the glasses when charging. When just using a USB cable, they will just lie around. Has anyone seen some nicer charging solution that can be used for these glasses?
steve1977: Thanks. We were looking for some nicer way to store the glasses when charging. When just using a USB cable, they will just lie around. Has anyone seen some nicer charging solution that can be used for these glasses?
I just charge my glasses when necessary and not when they are idle. Just put the cables in a small box and you have a solution :)
