Dear All,
I'm the happy owner of a BeoSound Ouverture plus BeoLab 8000. But since two month, i've discover the incredibly quality of the Full Digital amp (FX Audio D802 in my case). I've read a lot about and i decide to try on my BeoVox CX 100. The result is simply amazing ! I rediscover the very high quality of this CX 100 ! The sound is incredibly clear and the stereo scene is in real 3D ! Voice and instruments are full of detail and clearly separated ... Amazing !
So i decide to try this amp with my BeoLab 8000. Even the install is a little bit complicated with the converter and son on, the result is as fantastic as i expected ! The only problem comes form the amp. Even it's off, it provide background noise to the BeoLab 8000 that they can't shut down ...
I don't want to come back to the Ouverture and the BeoLab 8000 integrated amp ... the difference is to big to come back ...
I think to buy a pair of BeoLab Penta that have a Speaker Link to be connected to a normal amp.I'm correct ?
I've found one pair ... but one of them have a problem on the integrated amp. The amp shut down after few minutes.
Question : if i only need the Speaker Link function on this Penta, it's a problem to have one Penta with an amp problem ?
Thanks for your answer !
Many thanks leosgonewild for your reply !
Is it a complicated operation ?
