Hi all,
I saw today a new update for my essence and beaoplay A6. I made the update but didn't found anything related to this new version.
Did you find it or have you noticed anything ?
Here is the version now installed on my hardware : 1.5.376.31186857.
Christophe.
Beolab 1, Beovision 7-32, Beosound Moment, Beolab 18, Beolab 19, Beoplay A6 Grey, Beoplay A6 Black, Beolit 15, Beoplay H7, Beosound Essence mkII waiting for speakers :)
BeoVision Eclipse 55”, Beolab 18s, Beolab 19s, Beosound 1, Beoplay P2, H3, BeoRemote One IR, BeoRemote One BT, Beoplay S8, Beosound Essence MkII, BeoTime
The previous changelogs can be found on the B&O Product Support page.
I guess that will be updated (sooner or later) - even if the 1.4 update isn't listed here yet :-(
Maybe one of the dealers/BW members already know more.
Was GOOGLE Cast available on the A6 prior to this upgrade, I don't remember .... It is now!
No Google cast was not available, so that's part of the improvment :)
But I see my A6 in the Google Cast app, but not the Essence MKII :(
Seems to be only for the Play-branded systems:
http://www.beoplay.com/landingpages/googlecast#at-a-glance
I wonder what is the logic behind that - hardware limitations, or?
Anyway - for me as an iOS-user not that important.
I can cast to my Essence mk2 after this update so keep trying.
Although, if Chromecast was just added,, how did Spotify work before this?
et voilà:
http://www.beoplay.com/landingpages/googlecast?utm_campaign=w19-Get%20casting&utm_medium=email&utm_source=newsletter
Spotify is using a proprietary solution with SpotiFy Connect
Stan: I can cast to my Essence mk2 after this update so keep trying. Although, if Chromecast was just added,, how did Spotify work before this?
So you must be a magician :) now changelog is available and no Google cast for essence...
Not a magician, but perhaps confused with terminology.
From the Spotify app, I see the Essence as a "Spotify Connect" device, just like I see my Chromecast. If this is not "Chromecast", sorry, I guess I don't know what I am talking about... aside from knowing that I am streaming from Spotify to Essence without using my phone. Further investigation shows that TuneIn doesn't show the Essence as a cast device so it must not be. Oh well.
At least I answered my own question above of how did it work before the update... Apparently, the same as after. ;)
New on this software : it is now possible to "push" music using DLNA protocol to my Beoplay A9, which was impossible since I got it (march). It was possible to do that with a mkI beosound essence at release.
In simple words, it allows to use a lot of apps instead of Beomusic to listen to music on the BS9, without having to stream from a phone (battery will last longer), and to use a lot of PC/Mac softwares.
diisign.com
v. 1.5.376.31186857 – Released 11.05.2016
- For more information see: http://www.beoplay.com/googlecast
- Google Cast can be activated via the BeoSetup App
I just noticed a Bluetooth Remote Control option in the A6 setup, which Remote Control are they referring to?
mbolo01:I just noticed a Bluetooth Remote Control option in the A6 setup, which Remote Control are they referring to?
BeoSound Essence Remote
hadr: mbolo01: I just noticed a Bluetooth Remote Control option in the A6 setup, which Remote Control are they referring to? Maybe the upcoming BeoRemote One BT?
Could you tell us some more about this setting - maybe a screenshot of the setup?
Thanks.
Interesting!
A setting with 'My Buttons' can only relate to the BROne - maybe a hint too for the coming BT version.
I guess we will soon know more, since that should cone with the new tv(s).
Anyone, who knows more???
