Beogram CD 4500 - heavy disturbance
This post has 3 Replies | 0 Followers
wixia
Posts 2
wixia Posted: Mon, Jul 23 2012 8:13 AM
Hello,
I have a Beogram CD 4500 connected to a Beomaster 4500. When I play a disc the only sound I get is heavy disturbance. I can hear that the disturbance alternates according to the CD but I can't distinguish any real sound or music at all. The radio works just fine and so does the tape player that I also have connected to the Beomaster so the problem must lie within the CD player.
Can anyone think of what the problem might be and what can I do to fix it?
Regards!
solderon29
U.K.West Midlands
Posts 764
solderon29 replied on Mon, Jul 23 2012 10:36 AM
By disturbance,do you mean distortion?
Is the disc being read normally,eg,is the track display etc working?
It seems like a problem with the cd decoder,but if you are not technical,you will need expert help.
Nick
wixia
Posts 2
wixia replied on Mon, Jul 23 2012 12:41 PM
Hello Nick, thank you for your answer.
By disturbance I mean that I only hear roar/noise/rush instead of the music. The noise alternates though so I get the feeling that the CD player plays the disc but something happens with the signal on the way to the speakers. The disc is read normally, i can skip between the different tracks and the track display works perfectly.
I am pretty technical and can easily replace parts, I just need some guidance regarding which part I need to replace or how to decide which part to replace.
Regards
stefan
200 miles from Struer
Posts 2,920
stefan replied on Mon, Jul 23 2012 2:00 PM
Did you try to connect the CD to the A.TAPE input and control it via A.TAPE?
If this works, the fault should be in the BM4500 - CD input? - if this doesn`t work either, it must be the BG CD or the cable....
And if you have the BC4500 connect it to the CD input.
Hope this helps
Stefan
Page 1 of 1 (4 items) | RSS
