Hi
heve question belts for BEOCORD 2000 have this same size as BEOCORD 3300 and if anyone has installation instructions belts in the model 2000
Yes, the belts are identical for the two decks.I can supply correct belts and mounting instructions can be included.I also have the idler / reeltable rubber parts.
So they are same im have belts but dont have instruction... can u share me this instruction?
If you bought on Ebay etc. there's a fair chance that the belts you bought won't fit.In any case, to be fair, I think the right person to ask would be the seller/supplier.Martin
I bay belts on flea market. Belts from Thakker GmbH and i not get instruction from the seller
I can pay 4 the instruction ;)
Please can You halp me with this instruction?
You are my last hope
And one more question:
I removed all remnants of the belts , and when I press play to the second automatically jumps me to stop . Is it normal
If the tape isn't running correctly, the deck will stop. Without belts the deck will not be running correctly - so it stops.That's normal.I have correct belts and also the idler and reeltable rubbers.You have email.
