BEOCORD 2000 belts
This post has 6 Replies | 0 Followers
bzikiers
Posts 12
bzikiers Posted: Thu, May 26 2016 6:27 PM
Hi
heve question belts for BEOCORD 2000 have this same size as BEOCORD 3300 and if anyone has installation instructions belts in the model 2000
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Thu, May 26 2016 9:43 PM
Yes, the belts are identical for the two decks.
I can supply correct belts and mounting instructions can be included.
I also have the idler / reeltable rubber parts.
bzikiers
Posts 12
bzikiers replied on Sat, May 28 2016 2:43 PM
So they are same im have belts but dont have instruction... can u share me this instruction?
Dillen
Posts 13,191
Dillen replied on Sat, May 28 2016 4:18 PM
If you bought on Ebay etc. there's a fair chance that the belts you bought won't fit.
In any case, to be fair, I think the right person to ask would be the seller/supplier.
bzikiers
Posts 12
bzikiers replied on Sun, May 29 2016 1:14 PM
I bay belts on flea market. Belts from Thakker GmbH and i not get instruction from the seller
I can pay 4 the instruction ;)
bzikiers
Posts 12
bzikiers replied on Tue, May 31 2016 5:37 PM
Please can You halp me with this instruction?
You are my last hope
And one more question:
I removed all remnants of the belts , and when I press play to the second automatically jumps me to stop . Is it normal
Dillen
Posts 13,191
Dillen replied on Wed, Jun 1 2016 8:59 AM
If the tape isn't running correctly, the deck will stop.
Without belts the deck will not be running correctly - so it stops.
That's normal.
I have correct belts and also the idler and reeltable rubbers.
You have email.
Page 1 of 1 (7 items) | RSS
