Sound sync on Beovision 11
This post has 11 Replies | 2 Followers
Chris Hassell
London
Posts 396
Chris Hassell Posted: Tue, Jun 7 2016 3:15 PM
Hi there, I've got a couple of borrowed Beolab 3's as rear in the bedroom on my BV11. They sound amazing (although the wife still doesn't like the look of them so probably going to have to go back very soon) but the sound seems to be a bit out of sync. Are there options I should be looking at in the BV11 menu?
BeoVision Eclipse 55”, Beolab 18s, Beolab 19s, Beosound 1, Beoplay P2, H3, BeoRemote One IR, BeoRemote One BT, Beoplay S8, Beosound Essence MkII, BeoTime
mjmedlo
Posts 922
mjmedlo replied on Tue, Jun 7 2016 3:50 PM
Chris Hassell:
BV11-46, Beoplay A2, H3 ANC, Beo 4, Beoplay S8, Beosound Essence MkII
Numerous settings in the bv11
Hit menu/setup and choose sound.
There are a plethora of options.
MJM.
Millemissen
Flensborg, Denmark
Posts 14,680
If you want to dig deep - you'll have to read the Technical Sound Guide (available on the BV11 user guide site).
Hiort
Sweden
Posts 2,895
Hiort replied on Tue, Jun 7 2016 4:52 PM
Chris Hassell:
Strange.
Out of synch with the sound coming out from the BV11? Or with each other? Have you selected Beolab 3 when setting up the surround?
riverstyx
SouthWest UK
Posts 938
Hiort:
Also check the distances of each speaker (as measured relative to the listening position) are set correctly as big variations in these settings can cause sync issues.
Martin.
Chris Hassell
London
Posts 396
riverstyx:
Martin.
Ahhh could be this. I'll reset distances to 0 and see if that helps. It's the dialogue that seems out of sync.
Hiort
Sweden
Posts 2,895
Hiort replied on Tue, Jun 7 2016 7:12 PM
Chris Hassell:
Ahhh could be this. I'll reset distances to 0 and see if that helps. It's the dialogue that seems out of sync. BV11-46, Beoplay A2, H3 ANC, Beo 4, Beoplay S8, Beosound Essence MkII
Dialogue should come from Centre speaker.
The Beonic Man
Bristol
Posts 812
...and the distances won't be 0 for any of the speakers except the BV11 centre! So measure how far back the 3s are (and any additional fronts) and set accordingly. Cheers, Simon.
B&O products are V1-32, BS2, H95, E8 and an Essence remote.
11-46 now replaced with Sony A90J 65”, Sony HT-A9, Sony UBP-X800M2 and Sony SRS-NS7.
riverstyx
SouthWest UK
Posts 938
BAND'OH!:
The distance won't be zero for the BV11 centre speaker either unless you usually sit with your face pressed against the centre speaker frets  Wink
The distances should be measured between your listening position and each of the speakers (not from the TV to each of the speakers) as they are used by the BV to calculate how long the audio will take to reach you, and adjust the relative timing of each speaker accordingly.
Martin.
The Beonic Man
Bristol
Posts 812
Thanks for the correction :)
Chris Hassell
London
Posts 396
I think I had my distances set as too far (like almost 4 meters instead of 2.5m or so. Cheers gang.
The Beonic Man
Bristol
Posts 812
Yes I have also readjusted mine too and one of them was 2m out. I am not entirely sure I am noticing a difference from before but feel pleased that the distances are at least now correct. Thanks, Simon.
Page 1 of 1 (12 items) | RSS
