hi all
I have a beov 8-26 hooked up and working well enough as a pc monitor via hdmi - however it is pretty dark - even with the brightness up high
any advice gratefully received!
Hi,- kmspurway
Without knowing exactly what you are hooking up to your BV8..
This Google search might help you : " blacker than black htpc"
BeoNut since '75
