Idea for bathroom
This post has 16 Replies | 2 Followers
Seanie_230
UK
Posts 2,278
Seanie_230 Posted: Sat, Jun 11 2016 2:04 PM
Hello beopeople
I am having my bathroom done up soon and a newly plastered ceiling
The walls will be tiled.
My house is pretty much NL only now.
What cables do you recommend I put in for the future maybe just mains and cat5 read for a future NL device ?
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
mjmedlo
Posts 922
mjmedlo replied on Sat, Jun 11 2016 2:27 PM
Seanie_230:
Hello beopeople
What cables do you recommend I put in for the future maybe just mains and cat5 read for a future NL device ? BLGW - Rekindling the love of ML
At least two cat 5.
Preferably a cat7 if you can get your hands on it
BeoIce
Recklinghausen, Germany
Posts 751
BeoIce replied on Sat, Jun 11 2016 3:39 PM
Use CAT.7  cables and stay away from the cheap CAT.5 cables. They miss the paired shielding which you may needed in some cases.
B&O recommends to use CAT.7 cables anyway.
Some years ago I did my flat with CAT.7 cables too and am very pleased with it.
BeoSound 9000 MK3, BeoLab 8000, BeoLab 6000, BeoLab 3500, LCS9000, BeoLab 11, BeoLab 7.2, BeoLab 7.1, Beolab 4 PC, BeoCenter 2300, BeoSound Century, BeoSound 8, Beosound 2, BeoVision 7-40 MK2 , BeoVision 7-32 MK3, BeoVision 6-22, BeoVision 4-42, BeoMedia 1, BeoCom 4, BeoLink 1000, BeoLink 5, BeoLink 4 & BeoTime
Chris
Ostend-BE
Posts 1,170
Chris replied on Sat, Jun 11 2016 7:23 PM
BeoIce:
100 Gb .... in a residential ... Wonderful .... Will you be an ISP? Which device needs the required 100 Gb?
Copying from PC to NAS and back goes 750-800 Mbps ... maximum of the NIC.
"Believe nothing you read and only half of what you see, let your ears tell you the truth."
Lee
Newcastle upon Tyne UK
Posts 734
Lee replied on Sat, Jun 11 2016 7:44 PM
I think the recommendation for CAT 7 is more to do with the improved shielding than the potential 100gb bandwidth Stick out tongue
Chris
Ostend-BE
Posts 1,170
Chris replied on Sun, Jun 12 2016 6:57 AM
Lee:
Actually that recommendation is probably a safe case for B&O. But you still have to mount Cat6a connectors to Cat7 cable, because the specified Cat7 connectors are specially designed for higher frequenties and not usable directly on B&O devices. But we deviate from the question, the bathroom.
I would suggest to place any type of network cable as long as you stay away from Cat5. Install at least one cable to the bathroom for future use.
Further more, take a good look at your wireless quality, do you have a decent signal in the bathroom. Not long ago people declared me crazy to hardwire because WiFi is the future, they say. Meanwhile, every average lunatic goes wirelessly with the most trivial equipment. Tasty interfere with each other, competed to see who has the best signal in the area and then cry you have a dredging signal in your own shack.
A wired network is always preferable and gives you a more assured connection to all devices. As long as B&O gives you the choice to hardwire their devices, use it.
L1NO
Posts 250
L1NO replied on Sun, Jun 12 2016 7:29 AM
As the cables can be used for analogue audio e.g. Masterlink cat7 is the best bet for installers in B&O setting?
BeoIce
Posts 751
BeoIce replied on Sun, Jun 12 2016 3:11 PM
Lee:
This is what it's all about. It's because of the improved shielding ! Bandwidth doesn't matter in a B&O installation.
I use CAT.6a wall mounts and a CAT.6a patch panels in combination with CAT. 7 cables.
Get the best you can afford because you never know what future will bring.
In my installation I run powerlink, masterlink, ethernet, coax digital, analog, hdmi 1080p and even signals from the B&O ir-eye to the relevant devices without any problem at all.
Seanie_230
UK
Posts 2,278
Cheers all
I will run in two cat cables best I can and a mains cable just above the toilet furniture.
Now I just need an NL device for the bathroom
A new version of the beolab 2000 would be great as no need for a beosound 35 in such a small room
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Seanie_230
UK
Posts 2,278
I think an A6 will be in order
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Chris Hassell
London
Posts 396
Seanie_230:
I think an A6 will be in order BLGW - Rekindling the love of ML
Still a bit big hey. I'd love an A2 sized multiroom device. Basically an Essence MKII with a built in speaker.
BeoVision Eclipse 55”, Beolab 18s, Beolab 19s, Beosound 1, Beoplay P2, H3, BeoRemote One IR, BeoRemote One BT, Beoplay S8, Beosound Essence MkII, BeoTime
Seanie_230
UK
Posts 2,278
Hi Chris
My thoughts exactly
I picked the A6 because it's the smallest MultiRoom device there is.
I don't need that much power in my bathroom at all.
If any of the fairies or sheep know something we don't about upcoming smaller MultiRoom devices do shout Big SmileBig Smile
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Hiort
Sweden
Posts 2,895
Hiort replied on Mon, Jun 13 2016 2:12 PM
Seanie_230:
Check out the rumors here Smile
http://archivedforum2.beoworld.org/forums/t/20562.aspx
elephant
AU
Posts 8,219
elephant replied on Tue, Jun 14 2016 1:38 AM
Seanie_230:
What the Elephants did yesterday was to broadcast a playlist from our MacMini's iTunes via Bluetooth to her A2 in the FS room and WiFi/Wired to the sitting room's BL20s and the living/family room's BV8 ...
Only problem is BT wouldn't stretch to our bathrooms ... hence why I have placed our iPad1 with WiFi inside its A3 in that area.
BeoNut since '75
badgersurf
Posts 539
I have a set of Beovox 1 speakers in the bathroom wall connected to a MCL2P which is connected to an Essence Mk2., both of which are stored in the loft above the bathroom
Works beautifully and sounds great in the bathroom
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Tue, Jun 14 2016 11:28 AM
badgersurf:
Same setup
Using iPod Touch wall mounted as remote (Beomusic, Hue)
Seanie_230
UK
Posts 2,278
What a great idea. Some simple bathroom speakers connected to a MCL2P all switched on and off with volume from an Essence MK2.
Could even go with IR and a Beoremote 1 on the wall.
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Page 1 of 1 (17 items) | RSS
