Eclipse 65V1-32Beosound M5Essence MK2BLI
Seanie_230:Hello beopeople I am having my bathroom done up soon and a newly plastered ceiling The walls will be tiled. My house is pretty much NL only now. What cables do you recommend I put in for the future maybe just mains and cat5 read for a future NL device ? BLGW - Rekindling the love of ML
Use CAT.7 cables and stay away from the cheap CAT.5 cables. They miss the paired shielding which you may needed in some cases.
B&O recommends to use CAT.7 cables anyway.
Some years ago I did my flat with CAT.7 cables too and am very pleased with it.
BeoSound 9000 MK3, BeoLab 8000, BeoLab 6000, BeoLab 3500, LCS9000, BeoLab 11, BeoLab 7.2, BeoLab 7.1, Beolab 4 PC, BeoCenter 2300, BeoSound Century, BeoSound 8, Beosound 2, BeoVision 7-40 MK2 , BeoVision 7-32 MK3, BeoVision 6-22, BeoVision 4-42, BeoMedia 1, BeoCom 4, BeoLink 1000, BeoLink 5, BeoLink 4 & BeoTime
BeoIce:B&O recommends to use CAT.7 cables anyway.
100 Gb .... in a residential ... Wonderful .... Will you be an ISP? Which device needs the required 100 Gb?
Copying from PC to NAS and back goes 750-800 Mbps ... maximum of the NIC.
"Believe nothing you read and only half of what you see, let your ears tell you the truth."
Lee:I think the recommendation for CAT 7 is more to do with the improved shielding than the potential 100gb bandwidth
Actually that recommendation is probably a safe case for B&O. But you still have to mount Cat6a connectors to Cat7 cable, because the specified Cat7 connectors are specially designed for higher frequenties and not usable directly on B&O devices. But we deviate from the question, the bathroom.
I would suggest to place any type of network cable as long as you stay away from Cat5. Install at least one cable to the bathroom for future use.
Further more, take a good look at your wireless quality, do you have a decent signal in the bathroom. Not long ago people declared me crazy to hardwire because WiFi is the future, they say. Meanwhile, every average lunatic goes wirelessly with the most trivial equipment. Tasty interfere with each other, competed to see who has the best signal in the area and then cry you have a dredging signal in your own shack.
A wired network is always preferable and gives you a more assured connection to all devices. As long as B&O gives you the choice to hardwire their devices, use it.
As the cables can be used for analogue audio e.g. Masterlink cat7 is the best bet for installers in B&O setting?
This is what it's all about. It's because of the improved shielding ! Bandwidth doesn't matter in a B&O installation.
I use CAT.6a wall mounts and a CAT.6a patch panels in combination with CAT. 7 cables.
Get the best you can afford because you never know what future will bring.
In my installation I run powerlink, masterlink, ethernet, coax digital, analog, hdmi 1080p and even signals from the B&O ir-eye to the relevant devices without any problem at all.
Seanie_230:I think an A6 will be in order BLGW - Rekindling the love of ML
BeoVision Eclipse 55”, Beolab 18s, Beolab 19s, Beosound 1, Beoplay P2, H3, BeoRemote One IR, BeoRemote One BT, Beoplay S8, Beosound Essence MkII, BeoTime
Seanie_230: If any of the fairies or sheep know something we don't about upcoming smaller MultiRoom devices do shout
Check out the rumors here
http://archivedforum2.beoworld.org/forums/t/20562.aspx
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Seanie_230:If any of the fairies or sheep know something we don't about upcoming smaller MultiRoom devices do shout
BeoNut since '75
I have a set of Beovox 1 speakers in the bathroom wall connected to a MCL2P which is connected to an Essence Mk2., both of which are stored in the loft above the bathroom
Works beautifully and sounds great in the bathroom
badgersurf:I have a set of Beovox 1 speakers in the bathroom wall connected to a MCL2P which is connected to an Essence Mk2., both of which are stored in the loft above the bathroom Works beautifully and sounds great in the bathroom
Same setup
Using iPod Touch wall mounted as remote (Beomusic, Hue)
